venting 2nd floor bath
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bwc, Dec 2, 2012.
  1. bwc
    bwc New Member
    Dec 1, 2012
    NB
    I am adding a new bathroom on the second floor. Can I tap into the vent from the first floor bath in the attic so to save from putting another vent through the roof? The horozontal distance is about 15'. If so, can I do it with 1 1/2" pipe (ABS)?
  2. jimbo
    jimbo Plumber
    San Diego, CA
    You can tap your 2nd floor vent into that. You can NOT put any WASTE into that vent line from the first floor. Your second floor vents cannot be horizontal ( less than 45 degrees) until 42" above the floor, and must ALWAYS have some minimum continuous slope back towards the drain, to avoid bellies which would fill up with rain water
  4. Hammerlane
    Hammerlane Member
    Oct 22, 2011
    see if this helps, what size is the vent going thru the roof? 3"?
  5. bwc
    bwc New Member
    Dec 1, 2012
    NB
    Thanks. That is helpfull
  6. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    If you are running a new vent through the roof you will also want to look at your local code. Many places will not allow a vent smaller than 3 or 4" to penetrate the roof due to the possibility of frost closure during the winter.
  7. SacCity
    SacCity In the Trades
    Mar 14, 2011
    Sacramento, CA
    If you are going to have a toilet in the bathroom, min vent size is 2 inch
  8. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Only if he's under the UPC. Under IPC it can be 1-1/2 and it doesn't even have to be in the same location as the WC
  9. hj
    quote; Under IPC it can be 1-1/2 and it doesn't even have to be in the same location as the WC
    THe IPC would probably allow it to be in the house next door, if that was the cheapest way to install it.
Similar Threads: venting floor
Plumbing Forum, Professional & DIY Advice Exceptions to horizontal venting under floor? Apr 27, 2015
Plumbing Forum, Professional & DIY Advice Venting new main floor bath.. will this work?? Jan 31, 2014
Plumbing Forum, Professional & DIY Advice venting second floor bathroom Mar 16, 2013
Plumbing Forum, Professional & DIY Advice Venting basement floor drain Feb 22, 2012
Plumbing Forum, Professional & DIY Advice venting required for 2 new basement floor drains? Feb 14, 2012
