psu244
Recently having an issue with gurgling sounds in toilet and tub drain once toilet is flushed. Checked drainage pipes and vent stack and found no clog. Water runs down drains just fine. However noticed the bathroom sink drain pipe that is slightly upward and likely collecting water, blocking vent pipe access for other drain pipes (see pic).
I also noticed wetness on basement ceiling around the toilet drain pipe. I replaced the wax seal under the toilet. Now the gurgling is worse and toilet also gurgles when shower is running. Toilet also flushes slower than before. If the issue is the upward drain pipe how can I fix it?
I appreciate any feedback and thank you.
