Vent type?
Discussion in 'Water Heater Forum, Tanks' started by Dshow, Sep 29, 2012.
  1. Dshow
    Dshow New Member
    Sep 15, 2012
    Indiana
    I have an AO Smith GPSH 50 100 power vent water heater that I will need to replace. Do I need to replace it with another power vent heater or can I get a non power vent water heater? (This has a PVC vent now, can I use the PVC if I get something else?)
  2. Cookie
    Cookie .
    Oct 7, 2005
    A conventional gas water heater cannot use a PVC flu pipe, it can only use steel, if you wish, to run a steel pipe up through the middle of your house you can do so, but if I were you, I would just get another power vent water heater and hook it up to the existing flu.
  4. jadnashua
    A conventional WH's exhaust it too hot and would burn, melt, or distort PVC. And, you will find that, depending on the model, you may not be able to reuse what you have since it might require a different size, or have restrictions on the length and/or amount of elbows, etc. that are in your existing run. Each model will have a max run length and pipe size set of requirements...IOW, they are not all created equal!
    You need to read the installation instructions carefully, or solicit a good plumber to ensure you have a safe installation.
  5. Dshow
    Dshow New Member
    Sep 15, 2012
    Indiana
    Thanks very much for your feedback. The existing WH is an AO Smith that I've read many negative comment about it being a dog... Has AO Smith's quality improved so I should consider another AO Smith or is there another brand I should look at?
Similar Threads: Vent type
Water Heater Forum, Tanks Transition Type B Vent to Single Wall Sep 18, 2015
Water Heater Forum, Tanks Which type of gas water heater tank makes the most sense (venting related question) Dec 18, 2013
Water Heater Forum, Tanks Any issue using Type B vent pipe from water heater back to chimney? Dec 17, 2009
Water Heater Forum, Tanks Atmospheric Vent WH in Garage Mar 2, 2017
Water Heater Forum, Tanks Power Vent Water Heater Venting Jan 13, 2017
