Dostoy320
From the Minnesota Plumbing Code:
"Horizontal vent pipes forming branch vents, relief vents, or loop vents shall be at least six inches above the flood-level rim of the highest fixture served."
Can I take this to mean that if I have only a lavatory on a vent pipe - the vent rises vertically from the lav drain the turns 90 degrees and runs horizontally only about an inch above the lavatory flood level to a vertical vent pipe, that this is OK because it's not a branch/relief/loop vent?
Helpful Plumbing Hints for Residential Construction by Bert Polk Plumbing Inspector Lincoln County
