Vent pipe termination distance over roof?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Scuba_Dave, May 12, 2009.
  1. Scuba_Dave
    Scuba_Dave Extreme DIY Homeowner
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    This is what I found on a search
    So 6" above the point where it exits the roof is OK?
    I also want to box this in to "hide" it somewhat as it will be viewable from the front
  2. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    What are we venting?
    Furnace?
    DWV?
    Water heater?
    Boiler?
  4. Scuba_Dave
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    That would help
    It's the existing vent stack for plumbing
    There is one on each side of the house
    Other side has 2 bathrooms- 2sinks/showers/toilets
    This side has kitchen sink
    Addition has been added on this side of the house
    So the stack needs to go up higher then the new roof
    Interesting that the old location was very close to a bedroom window that opened & gable vent
  5. hj
    vent
    What is REQUIRED and what is INSTALLED do not always agree.
  6. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    This is from the Illinois plumbing code. I hope some of the items in it are helpful.
    Section 890.1430 Vent Terminals
    a) Roof Extensions. Extensions of vent pipes through a roof shall be terminated at least 12 inches above such roof unless a roof is to be used for any purpose other than weather protection. If a roof is to be used for any purpose other than weather protection, the vent shall be extended at least seven (7) feet above the roof. (See Appendix K: Illustration D.)
    b) Flashings. Each vent terminal shall be made water-tight with the roof by proper flashing.
    c) Location of Vent Terminal. No vent terminal from a drainage system shall be directly beneath a door, window, overhang or other ventilating intake opening of the building, nor shall any such vent terminals be within 12 feet horizontally of such an opening unless it is at least two (2) feet above the top of such opening. (See Appendix K: Illustration E.)
    d) Extensions Outside Building. No soil, waste or vent pipe extension (except for vent terminals as provided in (a) and (c) above) shall be located on the outside of a wall of any building, but shall be installed inside the building. Vents located within an exterior wall or in a wall adjacent to an unheated space shall be protected from freezing.
    e) Flag poles. Vent terminals shall not be used for the purpose of supporting flag poles, television aerials, or similar purposes. ​
  7. jadnashua
    Note you need to take into account the pitch of the roof, as shown in one of the diagrams, to determine the height above. This would normally mean it must be more than indicated at the point of penetration unless it was a flat roof.
    You'd have to talk to the inspector about boxing it in as that would create other problems, and might mean it would still have to exit even higher. You want it above the anticipated maximum snow depth on the roof, too, so that may help dictate the height.
  8. Scuba_Dave
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    Thanks
    6" just didn't seem high enough
Similar Threads: Vent pipe
Plumbing Forum, Professional & DIY Advice How do I fix this vent cast iron pipe? Tuesday at 1:12 PM
Plumbing Forum, Professional & DIY Advice Mystery pipe: could this be a vent? Feb 11, 2017
Plumbing Forum, Professional & DIY Advice Basement Soil and Vent Pipes Feb 4, 2017
Plumbing Forum, Professional & DIY Advice Water on outside of PVC vent pipe in basement Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Updating laundry plumbing - vent and drain pipes Jan 21, 2017
