Vent issues
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by cloned1973, Oct 10, 2009.
  1. cloned1973
    cloned1973 New Member
    Oct 10, 2009
    East Syracuse, NY
    Hello I'm live in NY, can someone please let me know if this would work or am I way out of reaity. I just want to things the right way. If the drwaing is hard to see I'm sorry.
    Scott
    Any heads up would be great!
      File size:
      16.8 KB
      166
  2. hj
    dwv
    The way you have it drawn, the tub has at least three issues.
    1. It will not be vented
    2. It will have an "S" trap.
    3. The main vent does not conform to the area rule, and you cannot just increase it to 3" in the attic to make it conform.
  4. cloned1973
    Oct 10, 2009
    East Syracuse, NY
    Thanks for respondiing.
    Silly me for not drawing a trap on the tub, I have one there,
    If you notice the drain from the tub goes to the 2 "pipe.
    Just to the right it stops.
    1. can I connect that to the vent going to the attic?
    2. Or on the trap for the tub can come off with a T wye, one going to the drain and the other connection to the 2"vent.
    3. Any suggestions about the 2" vent in the attic going through the roof. I thought I read somewhere it must be 3". I can not get a 3" up to the attic.
    Sorry for so many questions, I'm close to finishing the bathroom and just want it right.
  5. hj
    dwv
    The lack of a trap in your drawing has nothing to do with it. The configuration of the drain line would turn whatever trap you use into an "S" trap and they are illegal. The vent can come off the horizontal line anywhere between the trap and the downturning 45. The only way to make what you have "legal" would be to connect the sink to the 3" riser, then run the sink vent to the attic and connect back to the main line at the point where you increase to 3". You would also have to extend the tub trap into the attic and tie it into the main line. Either both vents would have to connect at the same point, or the lower one would have to be where you increase to 3". In addition ONE of the two drains and vents, sink or tub, would have to be 2", the other could be 1 1/2".
  6. Terry
    Aug 17, 2004
    [​IMG]
    Plumbing looks more like this.
  7. cloned1973
    Oct 10, 2009
    East Syracuse, NY
    Thank you, I only have one floor to worry
    From the basement looking up, the tub is closest to the outside wall , then the toilet and the sink is at far left. Thank you will do my very best with that picture. It helps alot.
  8. hj
    vent
    A football coach once told a player to get into the game and stop the quarterback. He told the coach, "I will do my best". The coach told him, "Sit down. The guy out there is doing his best already."
  9. Cass
    Cass Plumber
    Nov 12, 2005
    Ha Ha Ha...I like that....
  10. cloned1973
    Oct 10, 2009
    East Syracuse, NY
    The toilet drain is three inch. It goes through the floor, There is a 2" vent on the first 90 elbow. Turns out I can not go up at this location. Can I go to 3 feet horizontal with this 2" vent then up the exterior wall. I have a 2" pipe going up the exterior wall that is connected to the 4" that goes outside.
  11. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    You can never go horizontally with a vent until it is 6" above the flood level rim of the highest fixture served. Flat vents plug up and then they don't work.
  12. cloned1973
    Oct 10, 2009
    East Syracuse, NY
    do I need a vent on the toilet line? no way to get a 2" up at this location.
Similar Threads: Vent issues
Plumbing Forum, Professional & DIY Advice Floor drain backup - toilet water disappearing - possible Vent issues Jan 14, 2013
Plumbing Forum, Professional & DIY Advice Basement Bathroom vent issues Jan 26, 2011
Plumbing Forum, Professional & DIY Advice Please help! Toilet/shower/venting issues Jan 12, 2008
Plumbing Forum, Professional & DIY Advice Vent Issues continued... Dec 29, 2007
Plumbing Forum, Professional & DIY Advice Bathroom sink remodel venting/drain question Today at 1:36 PM
