Vent flashing
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by noppenbd, Jun 7, 2012.
  1. noppenbd
    noppenbd New Member
    Jun 7, 2012
    Maryland
    I am building a new powder room (toilet & lav) and I need to install a new 1-1/2" vent through the roof. The piping will be PVC. The roof is essentially flat (1/12 pitch) and is a roll roof (composition type sheets approximately 4' wide), with a silver reflective coating applied to reflect solar energy. I am thinking of using a roof flashing which has a galvanized plate, with a neoprene boot that is flexible enough to accommodate the low pitch. Similar to this: flash01.jpg
    I would using roofing cement, slide on the flashing, then apply more roofing cement, roofing felt around the perimeter, and more roofing cement on top. Does this sound like a good solution?
    Dave
  2. hj
    IT is probably your ONLY good solution.
  4. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Will Maryland let you punch an 1-1/2 vent through the roof? Up here we can't use anything smaller than 3"
  5. noppenbd
    noppenbd New Member
    Jun 7, 2012
    Maryland
    We are not in the frost-closure area so it is my understanding that the 3" minimum doesn't apply.
  6. TTopPlumbing
    TTopPlumbing New Member
    Jun 7, 2012
    Leak Detection Expert
    Orange County, Ca.
    Coming from custom home plumbing you are on the right track. Typically you do not even need the flashing with rubber boot, just a galvanized roof jack with mastic is how most roofers complete the seal possibly using torch down. Copper flashing and lead flashings are another option.
Similar Threads: Vent flashing
Plumbing Forum, Professional & DIY Advice Metal roof- vent flashing, small ones for 2" & 1.5" Oct 17, 2016
Plumbing Forum, Professional & DIY Advice Roof vent flashing Jul 16, 2015
Plumbing Forum, Professional & DIY Advice Water test w/ lead roof vent flashing (aka roof jack) causes indoor shower Jan 30, 2011
Plumbing Forum, Professional & DIY Advice flashing for vent roof penetrations Nov 11, 2005
Plumbing Forum, Professional & DIY Advice Sidewall vent - distance from window/door Yesterday at 3:57 AM
