Vent damper
Discussion in 'HVAC Heating & Cooling' started by Ian Gills, Jan 22, 2008.
  1. Ian Gills
    Jul 24, 2007
    USA
    I recently replaced my Johnson Controls vent damper actuator on my 17 year old furnace.
    The actuator was seventeen years old and I saw a lovely updated model on E-Bay going at a great price.
    The old vent damper was starting to fail.
    My problem now is that I would also like to replace the stainles steel vent damper. The current vent damper (also 17 years old) is mucky and squeaks as it is turned. Does anyone know where I can buy a 5 inch vent damper without the actuator that will fit? I have looked everywhere.
    It seems I can only buy them with the Actuator at full price. Ouch.
  2. geno54
    geno54 New Member
    Jan 4, 2008
    Thats why you got a good deal on the actuator. In service, we would never replace just the actuator. We would replace the whole assembly. You'll have to order one that matches the model # of your boiler. You may need a pro due to some wiring harness issues that may arise.
  4. Ian Gills
    Jul 24, 2007
    USA
    Thanks Geno. Aha, I see the trick now. But I'll keep looking for the damper. One might turn up.
    The wire harness was OK. Plug and play. Although I was careful to make sure I did not cause a short (the wiring on some new actuators is not like that on old, even if the colored wires are the same color).
  5. Bill Arden
    Bill Arden Computer Programmer
    Sep 30, 2006
    computer programmer
    MN, USA
    If the damper is structurally sound you might consider just replacing the bushings that squeak. I've had good luck reaming out holes with a tapered reamer and then adding a bronze? bushing.
Similar Threads: Vent damper
HVAC Heating & Cooling Vent Damper Sticks Jan 25, 2008
HVAC Heating & Cooling FielVent Damper/Honeywell S8610 Ignition module wiring question? Mar 15, 2007
HVAC Heating & Cooling Can a bathroom vent exhaust duct be TOO short? Jan 30, 2017
HVAC Heating & Cooling AC vent letting cold air in when off. Jan 3, 2017
HVAC Heating & Cooling Venting 2 furnaces and WH Nov 22, 2016
