Vapor/moisture Barrier
Discussion in 'Shower & Bathtub Forum & Blog' started by rcrowley, Apr 27, 2007.
  1. rcrowley
    rcrowley New Member
    Apr 27, 2007
    I am completely remodeling my bathroom and after ripping out the old tile surround/drywall from my tub/shower I found that there was no vapor barrier behind it. After careful inspection I noticed no water damage in the walls and no moisture build up even without a barrier. If the process of redoing this area I am obvioulsy using cement backerboard and laying tile down again. Should I put in a vapor barrier this time around as well? My thought process is that if there was no water/moisture damage with drywall behind the original tiles there should be even less of an issue with a waterproof cement backerboard - any thoughts?
  2. jadnashua
    It takes only minutes, costs very little, and offers peace of mind (and meets code), so it is cheap insurance to do. Either plastic sheeting or roofing felt work.
  4. wexcellent
    wexcellent New Member
    Apr 29, 2007
    I've wondered the same thing before. However, the backer board manufacturers recomend it, every handyman book says to do it, and code calls for it so I think it is probably a good idea.
    I think part of it may be that there is more of a possibility of condensation in the wall void with the concrete backer.
  5. rcrowley
    rcrowley New Member
    Apr 27, 2007
    I know for the little bit of extra work to put the felt up it is worth it, but seeing as it never had ot to begin with and having drywall which is not water resistant I figured putting it back up that way with cement board would be at least better than originally. Given that fact and the fact that there was no water/moisture to begin with when I ripped out the original drywall I was trying to cut corners. Call me a little lazy. For the record - if it is coce - then why did it not have some sort of vapor barrier to begin with. My house was built in 67 so could this be something that took affect after?
  6. jadnashua
    It depends somewhat on where you live, how often you use the shower, and the ventilation in the room. Moisture moves from high to low concentrations. If the wall is dry, it will get wetter. Wood doesn't like wet, so try to minimize that transfer. Condensation in a wall is not something you want. On an older house, it is likely that the house does not have a house-wrap, and probably has more air changes than a typical house that meets today's efficiency goals. This would dissipate some of that moisture before it caused problems.
  7. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    no-one can ever know in advance how much water will migrate into the space in the wall cavity. Whether or not the humidity will be so high as to let mold grow, cannot be determined in advance. Code is an organized attempt to control these factors to the point where the result is knowable in advance. Vapor barrier here is an attempt at "sufficient knowledge". Without it you'll never know. REbuilding without a vapor barrier doesn't mean that all other factors will be the same this time. Furthermore, use patterns change over the years.
    david
Similar Threads: Vapor/moisture Barrier
Shower & Bathtub Forum & Blog Hydrobarrier applying Nov 10, 2016
Shower & Bathtub Forum & Blog 36x48 shower base for barrier free, back linear drain (48" side)? Jul 18, 2016
Shower & Bathtub Forum & Blog Shower Vapor Barrier Repair Nov 21, 2015
Shower & Bathtub Forum & Blog How to install a vapor barrier for use with a mud pan? Sep 6, 2015
Shower & Bathtub Forum & Blog Barrier-Free Safety Design Guidelines (safe guarding your hobless - no dam - no curb shower) Nov 10, 2014
