graycarpenter
- Messages
- 2
- Reaction score
- 0
- Points
- 0
I started out by replacing my shower in my 5 year old home. I found out through this site and John Bridges' site that the base was not set well and there was no vapor barrier installed. I determined this after I had totally tore out the shower including the tile walls.
I also came to the conclusion that the builder did not install a vapor barrier behind the green board. I am now ready to reinstall the base using a cement sand mix to set it in.
When I started to put back the insulation I realized that the builder put it in with the vapor side to the outside. Not good in Virginia. I check other places in the bathroom and realized it is wrong side out everywhere I can see it.
I called the building inspector and I asked why that would be since the rest of the home that I have looked at has the vapor barrier installed correctly. He said that they require the builder to put unfaced insulation in the bath areas because with they want to make sure there was not two barriers, one behind the backer board and one on the insulation He said they do not move the insulation once installed and the builder just turned it around so he wouldn't know that it is not unfaced. (I guess the builder didn't want to waste time.
Now what to do. The building inspector said that the faced insulation would have to be pulled out with the facing and the cavity filled. He recommended getting a contractor to blow insulation back in. I'm wondering about foam insulation. Would it work to take the old insulation out through a hole at the wall between each stud and then fill the cavity with foam insulation?
I have a second bathroom and it may have the same problem. I will open the wall above the bathtup/shower and check the insulation there. I won't be able to tell if there is another vapor barrier installed but I guess I can bet there is none because the master bathroom shower had none.
Sorry this is so long but I felt I had to give all the details I could think of. The foam is available from Tiger Foam and be put in by myself.
