I now this question has been asked a thousand times, but it seems
even on this site, some people say yes and some people say no.
Here is my specific situation. I live in a cold climate ( Canada). My home was built in 1954
and has siding on the outside.
I am going to put in a corner shower made by Maax,model- Azure ( 34" wx 42"l x81"h)
The 42" portion is on an outside wall. That outside wall is 8 feet long.
I plan on putting unfaced pink fiberglass insulation between the 2x4 studs the
entire length of that outside wall. Inside the shower stall itself I planned to
install DensShield drywall and cut it to size to fit with no seams except in the corner
where the other piece of DensShield will butt up against it. I will be using Laticrete
Hydro Barrier ( this product is similar to Redguard) on that corner joint.
I have been told NOT to put a vapor barrier behind the Dens Shield because it has
a vapor retardent in it. (On top of the Dens Shield I will be putting a Canadian product
called Duma Pan Panelling). Is this correct ?
The rest of the wall above the shower stall and beside the shower stall I planned
on using CGC 1/2" Sheetrock Mold Tough drywall gypsum 4'x8' panelling. This product
is described as ideal for bathrooms because it has been formulated for high humidity
areas and is moisture and mold resistant. I planned to NOT put a moisture barrier
behind that either. I will simply be painting over top of this product. Is this correct ?
There will be no tiles used anywhere in this bathroom. The bathroom is 8'x7' and 8'high and there
is a small window.There is no exhaust fan.( please do not suggest a fan ).
So, the bottom line is, I have been told NOT to put a vapor barrier anywhere on the
exterior wall. If there is any further information that I can supply please let me know.
Any help on this would be greatly appreciated.
Thanks.
Thanks.
