Vaper lock in a gravity fed water system.
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by KERRBEAR, Feb 10, 2013.
  1. KERRBEAR
    KERRBEAR New Member
    Feb 10, 2013
    CUTLER,OHIO
    I have a gravity fed wter system coming from a spring. I have water coming into the main line, but not coming into the house. I'm sure it has to be a vaper lock but not sure how to remedy the problem.
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Apply suction.
  4. hj
    IF there is any "positive pressure" from the spring, it will NOT vapor lock. The water will push the air out ahead of it.
  5. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    That would depend on how the line is run. If any of the line rises high enough, it may rely on siphoning to overcome the high spot.
Similar Threads: Vaper lock
Plumbing Forum, Professional & DIY Advice Broken sanitary tee in block Jan 29, 2017
Plumbing Forum, Professional & DIY Advice Kitchen sink drain blockage Jan 17, 2017
Plumbing Forum, Professional & DIY Advice Blocked supply line. Apr 24, 2016
Plumbing Forum, Professional & DIY Advice Plumbers STUMPED!! Sprinklers causing Airlock in Hot Water tank Apr 22, 2016
Plumbing Forum, Professional & DIY Advice Can't remove my old Moen Hydolock Feb 15, 2016
