Vanity supply and drain location?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by elgato, Sep 16, 2008.
  1. elgato
    elgato Member
    Jan 20, 2007
    Phoenix, AZ
    I am replacing an old 30" standard vanity with a 30" door/drawer type 33" tall.
    15" of the cabinet is covered by drawers leaving 15" to work with. Should the drain be centered in the 15" with the supplies on either side? Is 21" high for the drain about right for a 33" tall vanity?
    Thank You
  2. jimbo
    jimbo Plumber
    Most likely you will need to offset the supply and drain to clear the drawers. Take some measurements of the cabinet before you layout the plumbing.
  4. jadnashua
    For optimum locations of things, you really need to look at the spec sheet for the sink you choose...typically, they will have the preferred location of supplies and drain. Depending on if there is a drawer right under the top of the cabinet, or it has a blank space would determine where the sink can go...one of Newton's laws...two objects can't occupy the same space!
  5. hj
    drain
    The sink drain is going to right about at the edge of the drawers. The best place for the drain is within 2 1/2" of that location so you can make the connection to the trap by rotating the trap and not need offset fittings in the pipe to the wall. Water lines can be anywhere.
  6. elgato
    elgato Member
    Jan 20, 2007
    Phoenix, AZ
    Good point! Thanks. The trap only allows a maximum of three inches from center without an offset. This is why we ask before charging in.
    Not sure what sink I will order. Does 20 - 21" sound right for drain height in a 33" cabinet?
    Thanks again.
  7. jadnashua
    The height isn't the issue, it's the depth and width between the end and the drawers. Is it a drop-in or an undermount? You need to allow room behind for the faucet unless it mounts on the sink, too.
  8. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    I usually use 19" to center for basin drain and 22" for basin water supply
  9. hj
    trap
    Measure the trap before you depend on its maximum offset dimension. It could be 2 1/2" for a 1 1/4" brass trap.
Similar Threads: Vanity supply
Plumbing Forum, Professional & DIY Advice Bathroom vanity supply lines under vanity? May 9, 2014
Plumbing Forum, Professional & DIY Advice Supply to Double Sink Vanity and Shower... and Shower Hardware Aug 24, 2010
Plumbing Forum, Professional & DIY Advice Moving supply lines and drain on vanity Jan 18, 2005
Plumbing Forum, Professional & DIY Advice Back-to-back vanity DWV Oct 11, 2016
Plumbing Forum, Professional & DIY Advice IKEA Sink + Vanity Compatibilities Oct 10, 2016
