Vanity install
Discussion in 'Remodel Forum & Blog' started by jerome8283, Sep 11, 2008.
  1. jerome8283
    jerome8283 New Member
    Oct 4, 2006
    New York
    I have a half round vanity I would like to install. I also have a granite top which was fitted for it. The top and sink are attached to each other but not to the vanity yet. I also have a matching backsplash. This is my first time installing a vanity such as this and I have a few questions.
    1. Should the vanity and granite top lay flat to the wall?
    2. Do I attach the vanity to the wall first?
    3. What do I use to glue the granite backsplash to the granite top?
    Thanks in advance.
  2. jadnashua
    Anchor the vanity, then the top. The backsplash probably would cover any small gaps between the top and the wall. It would look best if the top was flush with the wall at the ends if you can do it. If the wall is bowed, that may not be possible. Same thing with the backsplash...granite won't bend to fit an uneven wall, but small gaps can be filled with caulk.
    I use a 100% silicon adhesive/caulk to attach the couple of slabs I have to the counter as well as the backsplashes. You can use a razor blade to clean off the squeeze out at the junction leaving an invisible joint - and use an alcohol wetted finger on any areas that may need a bead. If your wall is straight, you may not need any visible caulk at the top.
    Not all stone labeled granite really is, and some silicon can stain some stone. The stuff I have in my home hasn't been a problem. If you had this fabricated rather than buying a prefabed piece, check with the fabricator for their recommendation as to what to use.
Similar Threads: Vanity install
Remodel Forum & Blog Bathroon Vanity Install Issue - This was supposed to be the simple part! Oct 8, 2013
Remodel Forum & Blog Bathrom Vanity, Medicine Cabinet, Sconce Install Questions Sep 28, 2013
Remodel Forum & Blog New vanity install - P trap issue Mar 15, 2012
Remodel Forum & Blog Vanity Install Question Oct 13, 2008
Remodel Forum & Blog New Vanity - Notch to fit waste pipe or open wall and raise waste pipe? Feb 20, 2017
