Valve Stuck Open Question
Discussion in 'Irrigation / Sprinkler Forum' started by Duke76, Nov 11, 2007.
  1. Duke76
    Duke76 New Member
    Jul 10, 2007
    I have a Lawn Genie R706 anti siphon valve that will not shut off.
    I have opened it and inspected the diaphram and that looks good.
    I have flushed it out and there does not seem to be any sand or dirt inside.The solenoid makes a noise when activated. I've swapped the solenoid with the valve next to it in the manifold with no success.
    Can you suggest any other approaches before I change out the whole valve ? Do these valves generally fail in the open mode ?
    Thank you.
    Duke76
  2. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    R706 is probably a model number for a manual valve. You can probably purchase a new 'operator' assembly to replace the one that treads into the existing valve body.
  4. jimbo
    jimbo Plumber
    San Diego, CA
    Very small dings in seat or the diaphragm itself, or clogs in very tiny pilot passages can effect solenoid operated valves. You should not lose any sleep, or waste a lot of time trying to solve this problem. Just replace the entire valve, or as mentioned, the entire operating head may be replaceable without removing the valve body. Take the parts to the depot or a landscape supply house.
  5. Duke76
    Duke76 New Member
    Jul 10, 2007
    Thank you Jimbo and Wet Boots for your help.
  6. Wet_Boots
    Mar 23, 2007
    Metro NYC
    You can google up a complete adapter - try Toro L2034. I'd include an image, but the VBulletin transloader doesn't ever seem to work.
    [​IMG]
Similar Threads: Valve Stuck
Irrigation / Sprinkler Forum HELP! Valve stuck in open position Aug 11, 2010
Irrigation / Sprinkler Forum How to know which zone on valve goes to which sprinklers Feb 19, 2017
Irrigation / Sprinkler Forum Valve Box Too Low - Should I Stack Boxes? Jan 31, 2017
Irrigation / Sprinkler Forum Valve, station question Aug 16, 2016
Irrigation / Sprinkler Forum Irrigation valve will not open Aug 13, 2016
