Valve Seat Problem
Discussion in 'Shower & Bathtub Forum & Blog' started by DennisB, Oct 12, 2004.
  1. DennisB
    DennisB New Member
    Oct 12, 2004
    Hi,
    I am attempting to help my daughter stop a leaky tub faucet. She purchased a gerber kit that contains 3 valve stems with seats and all the other chrome hardware.
    I started on the hot water side and had no problem getting the old corroded valve seat out using the appropriate valve seat tool. However I could not get the new seat installed. I could get it started with my finger but when I tried to tighten it with the wrench it does not "catch". Fearing that this could get ugly (this is a converted apartment turned condo and the only access is through the front) I put the old seat back in. It now leaks worse than when I started.
    Any help is appreciated.
    Dennis B.
  2. e-plumber
    e-plumber DIY Senior Member
    Sep 1, 2004
    New York
    Here, Gerber is very popular. Are the parts that you purchased OEM?, this could be the problem if they aren't. If the threads that are in the faucet body got damaged when the new seat would not screw in easily, it may be beyond repair at this point. I would start over again with brand new seats and make sure the seat threads match the original ones that were in the faucet body.
  4. LonnythePlumber
    LonnythePlumber Plumber, Contractor, Attorney
    Sep 6, 2004
    Wichita, Kansas
    Compare Seats
    I agree with e that you should compare your seats. I think it's more likely you are not getting the new seat started correctly. Try a screwdriver that won't allow the seat to slip up on the tool and put sealant on the threads. You may not have gotten the old one back in tight enough or it has gotten debri behind it.
Similar Threads: Valve Seat
Shower & Bathtub Forum & Blog Replaced valve stem and seat and leak is worse! Nov 15, 2015
Shower & Bathtub Forum & Blog to clarify: Delta TPR type seat, is it the right one for the old valve? Jan 27, 2013
Shower & Bathtub Forum & Blog 1970's Delta single handle bath valve, springs, seats.........very confused...... Jan 27, 2013
Shower & Bathtub Forum & Blog Sayco valve seat May 25, 2009
Shower & Bathtub Forum & Blog Stuck valve stem seat Jun 17, 2008
