Valve ID Help, Peerless which was Delta's DTY line
Discussion in 'Shower & Bathtub Forum & Blog' started by tedBalog, Jan 30, 2011.
  1. tedBalog
    tedBalog New Member
    Jan 30, 2011
    Rittman, OH
    Hello Gents,
    I'm looking to do a small renovation of my bathroom, one step of which is updating my shower hardware. Currently, I have a chrome escutcheon and an acrylic handle. Up and down control volume, whereas rotating left and right control H and C respectively.
    I would like to update it to a brushed nickel handle, if possible without changing the valve. I don't have access to the rear of the valve.. I believe it might be a Delta 600 but no where on it does it say Delta. Here are some pictures:
    http://i38.photobucket.com/albums/e101/tedbalog/IMG_20110130_100032.jpg
    http://i38.photobucket.com/albums/e101/tedbalog/IMG_20110130_100543.jpg
    http://i38.photobucket.com/albums/e101/tedbalog/IMG_20110130_100600.jpg
    Thanks in advance.
  2. hj
    It is probably a Peerless which was Delta's DTY line. It uses the Delta ball, similar to the model 601, but probably has an adapter to convert it to the knob handle. Your main problem will be to find new trim with both bolt holes at the bottom and the proper size valve opening, the new ones have the openings on a diagonal with one at the bottom left and the other at the top right with a large valve body opening.
  4. tedBalog
    tedBalog New Member
    Jan 30, 2011
    Rittman, OH
    Thanks HJ, is it possible to convert it from the acrylic knob to a handle? HD carries a cheap escutcheon which looks like it will fit but has an acrylic knob which I'd like to get away from without changing the valve if possible. Otherwise it will have to wait until I replace the vanity and can get behind the valve.
  5. hj
    Delta's standard "old time" shower lever, and/or one from a lavatory will attach directly to the stem of the ball. It may work in "reverse", however, since the lever will be hanging down, while the "ball"s arrow was pointing "up".
  6. jimbo
    jimbo Plumber
    What type of stem does your ball have? For the acrylic handle it may have been a diamond, whereas the levers will go on a round stem.
Similar Threads: Valve Help
Shower & Bathtub Forum & Blog Help Identifying my shower valve. Sep 8, 2016
Shower & Bathtub Forum & Blog Nibco Series 600 unit Help identifying shower valve/trim Sep 6, 2016
Shower & Bathtub Forum & Blog Shower valve brand help Aug 21, 2016
Shower & Bathtub Forum & Blog Help identify this American Standard Valve Trim Jul 18, 2016
Shower & Bathtub Forum & Blog Help to identfy shower valve Jun 4, 2016
