Valve & diverter combination
Discussion in 'Shower & Bathtub Forum & Blog' started by Pimbley, Jul 3, 2007.
  1. Pimbley
    Pimbley New Member
    Jul 3, 2007
    I'm doing a shower and want a simple pb valve & three way diverter to feed a shower head, hand-held shower and overhead pan. No tub involed.
    I'm looking at the Kohler k-304 pb valve and k-405 three-way diverter valve.
    On the pb valve: Documentation says to cap the shower outlet and use the spout outlet for water fed to a diverter. If I do this the water will need to come down from the pb valve and around the valve and back up to the diverter valve, and somehow not hit the input water supply on one side?
    Also, the 405 has a 3/4 input but the 304 feeding it is only 1/2. Any problem converting from 1/2 to 3/4. Does that work ok?
    Thx
  2. Peanut9199
    Peanut9199 Customer Service Manager Plumbing Wholesale
    Apr 23, 2007
    Ontario, Canada
    Yes you have to cap off the shower side because water will come out of the spout side unless a diverter spout is closed forcing water up through the shower side.
    Reducing from 3/4" to 1/2" is fine all that will happen is the amount of water through the valve will be reduced.
    You are only suppling one unit at a time with a diverter valve so you will have enough with 1/2".
  4. hj
    diverter
    They recommend using the tub outlet because it is larger than the shower port. If you want maximum flow, use both and tie them together before connecting to the diverter.
  5. Pimbley
    Pimbley New Member
    Jul 3, 2007
    Thx
    Thanks all.
Similar Threads: Valve diverter
Shower & Bathtub Forum & Blog Upgrade Manufactured Home 2 Handle Valve with Bath Shower spout and diverter Jan 11, 2017
Shower & Bathtub Forum & Blog Unknown shower diverter valve, need help with ID.. Apr 17, 2016
Shower & Bathtub Forum & Blog Delta Diverter Valve Bonnet Nut Removal Apr 7, 2016
Shower & Bathtub Forum & Blog How does shower line drain through tub spout when valve is off and diverter is set to tub? Apr 3, 2016
Shower & Bathtub Forum & Blog How to get this diverter valve out Nov 18, 2015
