vACUUM RELIEF VALVE ON CLOSED LOOP SYSTEM?
Discussion in 'HVAC Heating & Cooling' started by CHRISUPNORTH, Nov 23, 2008.
  1. CHRISUPNORTH
    CHRISUPNORTH New Member
    Nov 23, 2008
    Hi, Chris here first time poster!
    I am putting a small infloor hydronic system together to heat a small addition. This is to supplement my existing forced air gas system.
    I am considering a Marathon hot water heater as the supply and the marathons come with a factory installed vacuum relief valve. My understanding of the vacuum relief is that it will let air into the system should a vacuum occur. Knowing that air in a hydronic system is not desireable should I remove the vacuum relief?
    Is there any possible way a vacuum could be created in a closed loop system?
    Regards,
    Chris
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    It won't make a difference.
  4. CHRISUPNORTH
    Nov 23, 2008
    You saying leave it, remove it and plug it all the same? I dont want to have the circ pump pull air into the system.
    Chris
  5. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Just leave it. The system is full and under pressure, the vacuum relief doesn't come into play unless you break a pipe. Why in hell's name are you using a water heater to for space heating? Like throwing money away?
  6. CHRISUPNORTH
    Nov 23, 2008
    I have lots of money to throw away!!! Just kidding.
    This is a one room addition that is open to the rest of the house. House is heated by forced air gas.... The hydronic heat in the floor is just a supplement. On the coldest day so far (14F) the room got down to 57F and I have not even insulated the crawl space underneith or blown in the ceiling insulation of r50.
    By my calulations I will only need about 7500 btu's to keep the room nice on the coldest days in my climate (about -13f).
    What else would you recommend?
Similar Threads: vACUUM RELIEF
HVAC Heating & Cooling vacuum vs non-vacuum valves in a 1 pipe low pressure steam heating system ? Jan 16, 2012
HVAC Heating & Cooling Both suction & discharge pressure drops into vacuum when unit runs. May 18, 2011
HVAC Heating & Cooling Recirculating central vacuum air Jul 28, 2008
HVAC Heating & Cooling pressure relief valve opens Jan 2, 2009
HVAC Heating & Cooling Oil Furnace Water Relief Valve Jan 24, 2008
