Vacuum relief on cold water feed?
Discussion in 'Water Heater Forum, Tanks' started by vtxdude, Jan 13, 2010.
  1. vtxdude
    vtxdude New Member
    Nov 28, 2009
    NH
    I can't remember what it is called but usually on the cold water feed to the water heater there is an extra brass piece that I think the plumber said is a vacuum relief something or other.
    When he put in the new water heater he said that they were no longer required. It was attached right to the cold water feed on my water heater but now I have just the straight copper pipe.
    Is this needed? Reason asking is that pipes seem a lot nosier now when a call for water is initiated such as washing machine or if WH is refilling etc
    Thanks
  2. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    Was your old model a bottom fed unit?
  4. jadnashua
    I don't know what the NH code is, but Nashua requires them on installation along with a tempering valve. Was a permit pulled and an inspection done? That would tell you for sure what was required. The vacuum breaker should(at least in my limited experience) have no affect on the sound of water running.
  5. vtxdude
    vtxdude New Member
    Nov 28, 2009
    NH
    Im talking about the brass fitting here off the cold water feed
    [​IMG]
    Plumber said no longer required
    What is it's purpose?
    Here is pic of new piping
    [​IMG]
    Tempering valve? You mean the T/P?
  6. FloridaOrange
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    Down here it's only required for a bottom fed unit.
    Tempering valve is not a T&P.
  7. Runs with bison
    Runs with bison Member
    Aug 23, 2009
    Midwest
    For process vessels typically a 150 psig rating was good enough to rate a vessel for full vacuum as well. Since the water heater relief is set to that I really doubt vacuum protection is necessary. For my process equipment design group it was customary to spec anything requiring moderate pressure (say 75 psig+) at 150 psig and full vacuum as there was little to be gained savings wise from lower pressure rating and it made the overall design simpler and more robust. Vacuum relief devices posed a lot of problem when boiling ether, gasoline, and other light hydrocarbons.
  8. jadnashua
    Vacuum will collapse a vessel more easily than pressure will blow it out. Regardless, if it is required by code in your area, you put one in if you want to pass.
  9. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    Is your water heater installed in the basement? If not is there any plumbing fixtures lower than the water heater?
    Here they are required if the water heater is installed above any other plumbing fixture. This way it will prevent vessel from collapsing if the water where turned off at the meter and someone opened a fixture.
  10. vtxdude
    vtxdude New Member
    Nov 28, 2009
    NH
    It is in the basement.....the plumber said used to be a requirement but is no longer..maybe different requirements for Nashua vs Merrimack? Who should be able to confirm? Water Dept?
    So the absence of this should cause any difference in pressure or cause more of a clicking noise at the meter (knocking noise at where meter is tied into the j-horn when water is being drawn) Seems like faster meter spins for washing machine, toilet, shower the louder the knocking noise..it is only at the pipe attached to meter...can post pic later to clarify
  11. SewerRatz
    Nov 20, 2008
    Chicago, IL
    Best person to contact to confirm if it is not required is the plumbing inspector from the building department of your city or town. Not having a vacuum relief valve will not affect how your meter is working or water pressure. It is a safety device to prevent a vacuum from collapsing the tank if the city shut of the main and someone opened a faucet below the heater.
  12. Runs with bison
    Aug 23, 2009
    Midwest
    Yes, and that is why it takes about 10x the internal pressure rating (150 psig) to achieve the 14.7 psi external pressure (vacuum) rating.
    I don't think I've ever lived anywhere that required vacuum breakers on the hot water tanks. I wonder if that is because the municipalities I've lived in three widely separated states typically have not had residential boilers? From what I've gathered here the design pressures of these residential boiler shells appear to be lower and therefore probably at risk of vacuum collapse. The boilers I've worked with have been industrial ones producing 600 - 1600 psig steam.
  13. hj
    vacuum valve
    Even where they are "required" the actual installation of the heater would determine whether it is necessary. Usually they are more of a nuisance that anything because they can develop leakage through the port.
  14. Jah0983
    Jah0983 HVAC
    Feb 5, 2011
    HVAC
    Manassas VA
    Hi all came across this thread and have been trying to get a ? answered. Is this an older style vacuum relief valve? Is it replaced by the watts N36-M1? Thanks in advance for any response!
  15. Terry
    Aug 17, 2004
    We would "guess" that it's a vacuum relief valve.
    Some places like to see them on electric tanks to prevent the elements from running dry and burning out.
Similar Threads: Vacuum relief
Water Heater Forum, Tanks Necessity of Vacuum Relief Valve - Not Pressure Relief Valve Oct 23, 2012
Water Heater Forum, Tanks Pressure relief valve question Friday at 5:04 AM
Water Heater Forum, Tanks Possible Pressure Relief Valve Leak Jan 16, 2016
Water Heater Forum, Tanks Routing relief valve line across concrete floor Jan 6, 2016
Water Heater Forum, Tanks Water heater relief valve drainage Mar 10, 2015
