Vacuum Head problem??
Discussion in 'Irrigation / Sprinkler Forum' started by JMerk, Jul 14, 2009.
  1. JMerk
    JMerk New Member
    Jul 14, 2009
    My sprinkler system decided not to work yesterday, it had worked fine for the last two years, no problems. I ran it in manual, nothing. I checked the rain sensor and it seems to be fine. I eventually got the system to run by turning the valve after the above ground "Vacuum or pressure" head on and off. The sprinkler system ran afterwards. This mornign I ran the system in manual again to check and nothing. I turned the valve on and off and it started fine. When the valve is turned open again I can hear water run through, is the vacumm head sticking or do I have a problem with a leak in the ground letting pressure bleed off?
    Thanks
  2. upper
    upper DIY Senior Member
    May 30, 2009
    Fresno, CA
    How many valves total and do they all not work? Upper
Similar Threads: Vacuum Head
Irrigation / Sprinkler Forum Questions about Pressure Vacuum Breaker Aug 7, 2014
Irrigation / Sprinkler Forum Noisy vacuum breaker May 19, 2013
Irrigation / Sprinkler Forum Watts 288A Anti-Siphon Vacuum Breaker Aug 6, 2012
Irrigation / Sprinkler Forum Wilkins vacuum pressure breaker issue? Sep 15, 2009
Irrigation / Sprinkler Forum Copper Fitting Leaking on pressure vacuum breaker-update info Sep 8, 2009
