Vacant home well issue
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by mikeazo, Oct 13, 2011.
  1. mikeazo
    mikeazo New Member
    Oct 13, 2011
    My offer was accepted on a home earlier this week. The inspectors were out today for the home inspection. I had them do a quantity and quality test on the well. They ran water from a hose outside for about an hour, then filled up a bucket with the outside water. The water was a light brown color. Inside the home, the water was clear as can be. There is a whole house filter, so I'm assuming that is why the inside water looked so good. The home has been vacant for 6 to 8 months. Could this be the cause of the light brown water? Is that color water on the outside a concern? I'm still waiting for the results of the bacteria test, but I'm guessing bacteria is not causing the color. I forgot to stick my hand in the bucket to see if it was sand or some other sediment. Could it be iron buildup since the well has hardly been used for so long? I've put as much info below as I could about wells in the neighborhood. Still waiting on a well log from the state department of natural resources though, so the best I can give right now is neighborhood information.
    Of the well logs I've seen for the neighborhood, the wells are between 40 and 50 feet. One log for a well just up the street said the aquifer type is gravel, another further up the street said sand and gravel. One was clay on top for 22 feet, then dry gravel for 8 feet, then clay for 6 feet, then gravel the rest of the way down. The other says clay for 10 feet then sand & gravel the rest of the way. Static water level is just over 20 feet on both.
    That is the best I can do for now. Hopefully I can get access to the well log for this home soon. Thanks for your help.
  2. Chad Schloss
    Chad Schloss Member
    Jun 18, 2010
    USA
    40 or 50 ft is the minimum in my area in mid michigan. we had a 30ft well with a static level of 20. hard water, iron bacteria, sand. etc. we eventually bit the bullet and had a new deep well drilled at a depth of like 200 or 300ft, i can't remember. they called it a rock well. water was very clear, very clean. before installing this new well, we had a softener and an iron filter, and two of those paper and carbon pre filters installed before this stuff and the water was still nasty. make sure to have your water tested for coliform, nitrates, iron bacteria, lead, arsenic, etc. I think these are all mandated, but if not make sure. they may have to chlorinate the well to clean it up, too. we did that fairly often. we had to pour bleach down the well, let it sit, then run it all night. the water still smelled the next few days and i made sure not to drink it. this is just my opinion, as a homeowner. i am not a plumber or water quality expert.
  4. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    I don't see a real problem unless the brown color continues. Anytime a well sets for some time they may pump discolored water for a time. When it's clear I would chlorinate the well with 1 gallon of chlorine mixed with 5 gallons of water. This may be a problem if it's a 1-1/4" or 2" cased well. Then turn on the pump and pump each house faucet until you smell chlorine then let them set for 24 hours. Then pump each faucet until you no longer smell the chlorine. Once this is done have a "Qualified" person to take a sample and immediately take the sample to a qualified laboratory for testing for coliform bacteria. It may or may not come back as safe to drink. If it doesn't pass, rechlorinate the well and repeate the process again. Most ground water is safe. It becomes unsafe when tampered with.
  5. ballvalve
    Dec 28, 2009
    northfork, california
    No inspector tests thru a mouldy hose. Maybe a house mounted bib. They should use the kitchen faucet after long run time.
    If you chlorinate Porky left out the "recirculate water thru the well cap" part, which I think very important.
  6. mikeazo
    mikeazo New Member
    Oct 13, 2011
    Not sure where the "mouldy hose" part came in.
    The inspector ran the outdoor hose for about an hour then filled up a bucket to see what the water looked like. For the quality test, he took a sample from the kitchen sink I believe.
    The problem was that even after running the hose for an hour, the water was still brown. Maybe that wasn't long enough though to fix the problem. The house had been sitting vacant for a while.
    Anyways, I should be getting the quality (i.e., bacteria test) results back on Monday. I'll update then. Then I'll probably have to talk to a company that works with wells to get an estimate so I can tell the current owner and have them fix it.
  7. Texas Wellman
    Texas Wellman In the Trades
    Feb 9, 2010
    Owner of a Water Well and Pump Repair Business
    SE Texas-Coastal
    Inspectors don't know squat about water wells. My money is on letting the well run for 5 minutes max before claiming the "brown water".
    Also if he did not flame the outlet and follow the procedures I doubt it will pass.
  8. mikeazo
    mikeazo New Member
    Oct 13, 2011
    You probably just lost your money then :) because I was there the whole time and watched while the water ran for an hour. Then I watched as he filled the bucket up and saw the brown water for myself.
    I'm curious as to what you mean by "flame the outlet". I've tried to find out what that means online, but couldn't find anything. Care to elaborate?
  9. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    My house sat empty for 2 years with no one in it. We chlorinated and pumped the well hours with little change. It took over a month of regular use before it looked pretty good. A couple of months later I figured out that the bottom of the pressure tank was full of iron sludge, as was the water heater.
    Before a water sample is taken for analysis, the water should be run for a minute or two and then turned off and the spigot sterilized with a flame (I use a propane torch) before the sample is taken. This spigot is considered contaminated until it has been sterilized and this contamination can effect the test results.
  10. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    That is at least possible. I used to have a well with a lot of iron, and there was definitely a difference between the water that came directly from the well and the water that had been filtered.
  11. ballvalve
    Dec 28, 2009
    You dont test through a hose. Hoses breed all sorts of irremoveable bacteria, half full in the sun. Kitchen, with a chlorine dip.
  12. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    I've read and reread the OP and it is not clear where or how the test sample was taken and to what end. There is also mention of a whole house filter but no explanation of it.
    I have a birm type iron filter that filters the "whole house" but not one of the outside hose bibs, so in my case, drawing from an unfiltered outside hose bib could result in water with a slight brown tint. Other outside bibs are plumbed after the iron filter and two of them are plumbed after the softener to supply hot and cold filtered soft water.
    As for drawing a water sample for testing, it would depend what I'm testing for. A sample drawn from the kitchen faucet would be of filtered and softened water so would not be representative of the water straight from the well. In my case, the one outside unfiltered bib, suitably flamed with no hose attached still would not provide a proper representation of the well water since it has been aerated by my micronizer and the iron turned to iron oxide, skewing the test. For a true test for iron, I have to draw a sample before the micronizer.
    A home inspector that is not a qualified ground water consultant might not provide a fair report nor a proper test.
  13. mikeazo
    mikeazo New Member
    Oct 13, 2011
    Not sure why there is so much confusion, I thought I was pretty clear. The inspectors did 2 tests. One to measure quantity, one to measure quality. To test quantity, they turned on an outside bib and left it running to see how many gallons per min they could get (quantity). They said that was around 5 to 7 gpm. Then to test quality, they took a sample from the kitchen sink. I didn't see them flame/sanitize the outlet, but that doesn't mean they didn't. Still waiting on the results of the quality test.
    The brown water was coming out of the bib and was still brown after an hour.
    Since I don't own the house, I don't know much about the filter or hookups. There were a few brand new filters there labeled "OmniFilter". Apart from that, I don't know much else about the filter. I'm assuming that the inside water is running through that filter and that the outside water is not. My assumption is based on the fact that the indoor water was crystal clear all the time (even when the bib water was brown). The water in the bucket was dark enough that I couldn't see the bottom of the bucket (there were probably 3 gallons in the bucket).
    How's that explanation? Hopefully better, and sorry for the confusion. If you have specific questions, please ask, and thanks all for all the help.
  14. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    One might infer from that statement that there was a hose involved.
    There was no mention in your first post where the quality sample was taken from and what quality metric you are looking for. If quality is to include hardness, iron, turbidity, etc., the test should be done at the wellhead.
    The quantity test is somewhat dubious and assures only a minimum GPM rate and total volume of 300 - 420 gallons. The GPM measured was what the bib and or attached hose can produce. The pump/well could probably produce much more. A thorough test would also measure the static level in the well before and after continuous pumping.
  15. mikeazo
    mikeazo New Member
    Oct 13, 2011
    All, thanks for all the help. And sorry about the confusing first post. Hopefully things are clearer now (no pun intended).
    Anyways, got some pictures today. These are from the inspection.
  16. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    At this point, it really does not matter what the water looks like. The only thing that matters is what the water test results are. If the well has been sitting for a long time the water will not be clear. It is pretty common that a well will need to be run for days to clear well. If the coliform test is bad, then you have a problem.
  17. ballvalve
    Dec 28, 2009
    Fecal coliform, anyway.
    A few days before the test, you really need to do a complete chlorine flush with well recirc. You can still give that a try with a questionable result. Fllush it a looong time everywhere before the next test through the sink.
  18. mikeazo
    mikeazo New Member
    Oct 13, 2011
    Thanks both for the info. That is what I really wanted to know. The problem now is that I don't actually own the house yet (closing next month). So, I probably can't go run the water for a few days or do a chlorine flush with well recirculation. I'll tell the seller that I want them to do that for us before we move in. Then probably do it myself again once we close.
    Thanks again everyone for all the help.
  19. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Have a clause put in the contract for the home sale. I would not buy the home until it has a known good well as proven by the well test. This is a common real estate clause that an agent will be familiar with.
  20. mikeazo
    mikeazo New Member
    Oct 13, 2011
    The well test came back negative.
    The water from the bibs was still colored when I went back to the house about a week after the inspection. Upon my realtor's advice, I had a plumber come out to look at things. The plumber suggested having someone pull the pump out and testing the line for high pressure leaks which could be stirring up mud. Do you think it would be worth it? The quote for doing that was $250.
  21. Chad Schloss
    Chad Schloss Member
    Jun 18, 2010
    USA
    whatever you do, i would suggest that the seller set money aside in escrow for the repairs if possible. i would allocate $500, enough to cover the $250 plus extra if anything else should come up.
Similar Threads: Vacant home
Pumps and Tanks Well Forum & Blog. Water is life. Lead Levels in Vacant House Well Jun 26, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Vacant well failed quality test, when to retest? Jun 4, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Well Pressurization pump causes oscillations in home plumping system Nov 13, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Large capacity well (100gpm) and home use Sep 13, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Water pressure issue with irrigation and home Aug 22, 2016
