UTP Video Balun Pair for Cat5
Discussion in 'Bob & Don's Electronics Forum' started by DonL, Nov 7, 2011.
  1. ballvalve
    Dec 28, 2009
    northfork, california
    Anyone know what passive keystone type over cat5 bezel means?
    There are two 1/6" holes on the rear, and no instructions of course. Perhaps those top tabs are to engage the cable, but everyone says they only use one wire of the cat 5 cable.....
  2. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    You use 1 twisted pair , 2 wires in the Cat5 wire and connect to the 2 connections.
    That gives you 3 more pairs for three more Cameras or other things.
    Just make sure that you connect the same Pair of wires on the other end of the wire.
    Pairs are 1 wire with a solid color then 1 wire with a white strip, and will be twisted together. 2 (Two) Wires.
  3. ballvalve
    Dec 28, 2009
    thanks. But i screwed up with these, as now I have to screw with cutting off the ends and stripping that little stuff.
    Now the dog cut a 200' cat5 cable. Can I splice these in the primitive method, cut strip and wind?
  4. ballvalve
    Dec 28, 2009
    repeat. maybe terrys update didnt do the job after all.
  5. ballvalve
    Dec 28, 2009
    I'll try again: can one splice cat5 with strip and wind, or must one use crimps and connectors?
  6. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    If you do splice, You need the keep the TP Twist as tight at possible.
    And you do need a RJ45 crimper to crimp the connectors properly.
  7. BobL43
    BobL43 DIY Senior Member
    Mar 25, 2011
    Retired Industrial Automation controls/tech s
    Long Island, NY
  8. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Nice BobL®.
    Just make sure that you put the heat shrink on, before making the splice.
    And if you do go the connector method, Don't use Crossovers for the RJ45 F-F adapter, Use Straight Thru adapters.
    If done correct the splice should be better. Just try to keep the same twist.
  9. ballvalve
    Dec 28, 2009
    Thanks. splice and solder would likely exceed the cost of 200' of cat5 which is down to about 10 bucks and less with connectors. Maybe a muzzle for the dog would be cheaper yet.
  10. balunman
    balunman New Member
    Jan 19, 2012
    israel
  11. ballvalve
    Dec 28, 2009
    Thank you, thats what I should have had.... don't look easy to find.
    Alright - have them : http://www.svideo.com/videorj45.html?cmp=googleproducts&kw=videorj45
    By the way, in way of thanks, to solve your small issue with Iran, I suggest Israel 'borrow' an Iranian fast boat and atack an American destroyer or aircraft carrier in the gulf.
  12. PipeInspection
    PipeInspection New Member
    Apr 10, 2012
    New Jersey
    I'm new here, but was wondering why you would use Cat5 with Video? Cat5 has a 330 feet limitation without a repeater. Does the Power adapter work in place of the repeaters?
    Are you using the Video for Security or to watch your plumbing for leaks?
Similar Threads: Video Balun
Bob & Don's Electronics Forum Video Baluns for CAT 5 or 6 Cable Feb 21, 2013
Bob & Don's Electronics Forum Please recommend a proximity sensor, some lighting and video Nov 30, 2013
