Utility Sink Standpipe Conversion
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by thebigsee, Oct 30, 2009.
  1. thebigsee
    thebigsee DIY Member
    Sep 24, 2009
    Southern California
    My washing machine just overflowed the utility sink for the last time! I want to tear out the sink and have a 2" standpipe instead. The sink drain/trap is 1.5", goes into the wall with a cleanout right underneath it and a vent stack right above it. The house is built on a slab and all drains are cast iron (the vents all appear to be galvanized though). The cleanout looks like 2" but it's hard for me to tell for sure (do they make 1.5" cleanouts?).
    Before I start tearing out drywall, can anyone tell me at what point the 1.5" usually transfers to 2"? I am not sure how to proceed. The new standpipe/trap will all be 2" ABS and connected by a Fernco coupling, but just not sure where it will connect so there's not a bottleneck.
    Thanks
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    You must make sure the entire drain line is 2" or more. You can't put a 2" standpipe into a 1-1/2" drain. The rule is never reduce the size of a drain. You mentioned using a Fernco coupler. Fernco is a brand name that we often use incorrectly to refer to a neoprene sleeve with 2 hose clamps. This type of connector is illegal above ground. If you must use a clamping type connector, get the no-hub kind. These have a single clamp over the entire sleeve and will provide a much more ridged connection.
  4. thebigsee
    Sep 24, 2009
    Southern California
    I appreciate the feedback. I will use a shielded no-hub connector for sure, no worries there. And I understand about not creating a bottleneck, which is why I am asking where the 2" usually begins after a 1.5" drain -- I want to eliminate all the 1.5" and tie-in a 2" ABS standpipe/trap into the existing cast iron. I want to do this right so I never have to do it again!
  5. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    The 2in. usually comes thru the concrete and them changes sizes, most areas don't allow anything smaller underground. :)
  6. thebigsee
    Sep 24, 2009
    Southern California
    Thanks, that's what I figured. I suppose I'll have to cut the cast iron just above the plate, remove the vent stack along with the p-trap, then replace it all with ABS. I guess a no-hub coupling is OK with a vertical stack of ABS that will be about 12 feet tall?
  7. hj
    overfflow
    WHY did the sink overflow? Usually the reason for using a sink is because a standpipe drain might overflow. IF a standpipe is really better, and you do not just have a plugged drain, (which a standpipe would not cure), then you need a proper sized connection for it to go into the drain line.
  8. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    If you get a front loading washing machine, it will use much less water, and a whole lot less soap so you get far far less sudsing too. Then, the problem you now have may disappear completely. This doesn't increase your flow, but it stops the overflowing. A small front loading washing machine holds a lot -- it's surprising, compared to top loading ones. All front loading washing machines clean better than top loading ones.
  9. thebigsee
    Sep 24, 2009
    Southern California
    The sink has overflowed on several occasions. A couple times it was because the cast-iron pipes had become clogged with acrylic yarn and hair; I've since put lint filters on the lines and had no more problems with clogs.
    More often, it's because the drain opening has become accidentally blocked by a bit of laundry. I got one of these this week (http://www.innovationsexpress.com/Drain_Defender.php) and I have high hopes that it will stop future clogs from happening. But we're having our wood floors replaced and I want to eliminate all possibilities. Plus, that utility sink is an eyesore and takes up a bunch of precious room in our kitchen. We hardly use it as a sink anyways.
Similar Threads: Utility Sink
Plumbing Forum, Professional & DIY Advice How To Drain Utility Sink To Washing Machine Drain? Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Basement utility sink Jan 7, 2017
Plumbing Forum, Professional & DIY Advice Washing Machine with Utility Sink - 1-1/2" Drain! Dec 6, 2016
Plumbing Forum, Professional & DIY Advice Need help on planning washer & utility sink setup Oct 13, 2016
Plumbing Forum, Professional & DIY Advice Need help installing utility sink. Sep 7, 2016
