utica boiler leaky valve #2
Discussion in 'Boiler Forum' started by 4uzindian, Nov 12, 2013.
  1. 4uzindian
    4uzindian New Member
    Oct 2, 2013
    trenton nj
    this is regarding my posts from 10-13-2013 to 11-05-2013.the drip came back.it is on the threaded part of valve. i tighted it slighty twice before .i'm afraid if i tighten any more ti might break. any way i'll probally replace it.theres two incoming lines .do i have to drain and purge both when i install new valve.or just the one with the new valve.
  2. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    If it's just the packing under the nut that is failing, it's possible to replace the packing.
    Google-up yourself a video primer on how to do re-pack a dripping valve stem (a plumbing-101 type of task.)
  4. 4uzindian
    Oct 2, 2013
    trenton nj
    thanks for your reply.i'll google this next.but my main question is do i have to purge both return lines if i decide to put in new valve ?the stem is not leaking. whats leaking is the big screw thread that goes into the fittting thats soldered on the pipes.
  5. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    Any time you open up the system ANYWHERE on the system, you have to purge the air that was introduced. And since that air does move, it's not usually as simple as just purging one zone or one section.
    Have you found the vents & bleeder valves on your system yet?
    Re-packing the valve stem doesn't usually require swapping out the valve, so definitely start there first. You may get wet from the dribbles & sprays if the system is still pressurized when you do it, but the valve stem doesn't come flying of when you back the packing nut completely out:
    [​IMG]
  6. 4uzindian
    Oct 2, 2013
    trenton nj
    thank's so much for your reply. looking at this picture you displayed. go down to where the valve assembly screws into the t fitting .this is whats leaking. it is one and a half inch diameter. the valve stem is not leaking .stop showing me valve stem fixes..so what youre saying is i would have to purge both incoming lines if and when i decide to put in a new valve ?
  7. 4uzindian
    Oct 2, 2013
    trenton nj
    valve #1 002.jpg tis is part of valve thats leaking
  8. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    You'll have to de-pressurize the system first, but you can probably just back that out, clean up the threads, and re-seal it using teflon tape., but if you're handy with a torch & solder simply replacing it (and possibly the drain valve above it) doesn't look like a major project.
    I's also possible that tightening the packing nut (the smaller part where the shaft comes out) will stop the leak. Depends on exactly where the seepage is occuring internally in the valve assembly.
  9. 4uzindian
    Oct 2, 2013
    trenton nj
    i'm confused.you said depressureize system? you said back it out which means the threaded part of valve.can i back this out without depressureizing and apply teflon ?i tighted the valve stem nut a little .tommorw i'll post on how much water leaked.
  10. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    The part where you indicated it's leaking is not the packing nut, it's the part with the internal threading that the valve stem used move the gate up & down:
    [​IMG]
    Unscrewing the packing nut you'll get spritzed on, but if you unscrew the part connected to the main valve body with the pressure on it'll take the guts of the valve with it and give you a ~8-10 gpm gusher-shower, a real hosing-down!
  11. 4uzindian
    Oct 2, 2013
    trenton nj
    thanks so much fo the valve illustration.i did lossen the the part to the main valve body just a little yesterday and i indeed get a good soaking. then . as i said before i was worried if i tighted it any more it might break. so i did go ahead and tighten even more last night. so far since then it has not leaked one drop of water. i'm hoping this is fixed . i'm going to post tommorow to let you know the conddition of system. again thanks so much for your help.
  12. 4uzindian
    Oct 2, 2013
    trenton nj
    back again. there is no water dripping since i tighted valve body.thanks again for info. so as of now i'm going to close this post .if something comes up i' ll repost again.
Similar Threads: utica boiler
Boiler Forum utica ssc modcon boiler intake moan noise Nov 1, 2014
Boiler Forum 1989 utica boiler drips # 3 Feb 10, 2014
Boiler Forum 1989 utica boiler drips #2 Feb 4, 2014
Boiler Forum 1989 utica boiler drips Jan 30, 2014
Boiler Forum 1989 utica boiler/slihgt humm Jan 21, 2014
