Using Unions
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by BimmerRacer, Apr 22, 2009.
  1. BimmerRacer
    BimmerRacer Member
    Jan 8, 2009
    NOT a plumber :)
    Washington, DC
    Is there a better way to make this type of connection? I read that some locations disallow unions behind walls, I am not certain on laws here. I also read that unions are more leak-prone.
    I also read that using a reverse threaded fitting would eliminate some of these concerns, but can't seem to locate one, perhaps I am searching for a wrong thing.
  2. hj
    unions
    YOu must be anticipating problems, otherwise the tubing would be attached directly to the manifold. If unions were no allowed inside walls, there would be several million tub and shower valves, installed since the earliest days, which could not have been connected, because they ALL had union connections.
  4. BimmerRacer
    BimmerRacer Member
    Jan 8, 2009
    NOT a plumber :)
    Washington, DC
    I am not anticipating anything, this is a stock photo from Kohler. The servicability of the digital valve however is a potential issue.
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Oh you know it!
    I dread the day I get sent to fix one...
    I'm just so not interested.
  6. BimmerRacer
    BimmerRacer Member
    Jan 8, 2009
    NOT a plumber :)
    Washington, DC
    I hear you on that, but the same principal applies to any valve I would think, digital or otherwise.
  7. Redwood
    Dec 15, 2007
    Service Plumber
Similar Threads: Using Unions
Plumbing Forum, Professional & DIY Advice Using Rainfall Shower Head Jan 28, 2017
Plumbing Forum, Professional & DIY Advice Anyone using the Basement Watchdog Big Dog? Jan 18, 2017
Plumbing Forum, Professional & DIY Advice Toilet venting using wet and dry combination Jan 15, 2017
Plumbing Forum, Professional & DIY Advice Using a recirculation pump to prevent freeze up of a supply line. Dec 12, 2016
Plumbing Forum, Professional & DIY Advice Using heat cable on PVC drain???? Dec 4, 2016
