Using the same well for the house and the sprinkler system
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by ts, Mar 23, 2006.
  1. ts
    ts New Member
    Feb 21, 2005
    I have a shallow well (about 75ft deep) which the house water system is connected to. I have a sprinkler system already laid out, all I need is a pump. Can I connect the sprinkler pump to the same line coming in to the house pump.
    thanks.
  2. Terry
    Aug 17, 2004
    If you connecto an irriagation system to potable water (house water, drinking water, ect.) you will need an approved back flow device.
    That is for your safety.
    [​IMG]
    Series: 007
    Description: Double Check Valve Assemblies
    Size Range: 1/2 to 3 in. (15 to 80mm)
    Series 007 Double Check Valve Assemblies prevent the backflow of contaminated water into the potable water supply. It consists of a bronze (1/2 to 2 in) or fused epoxy coated cast iron (2 1/2 to 3 in) body construction that is easy to maintain and service. Series 007 is ideal at referenced cross-connections identified as non-health hazard applications. Check with local inspection authorities for installation requirements. Maximum Working Pressure: 175psi (12.06 bar).
    http://www.wattsreg.com/
  4. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    What kind of pump do you have now for the house? Jet or submersible?
    bob...
  5. ts
    ts New Member
    Feb 21, 2005
    I have a pump that draw water from the well into a holding tank, then another pump with a pressure tank pumps the water thru the softner and the house. When I went to buy the sprinkler, I told the salesman that I would connect this pump to the same line as the current pump which is attached to the well. He said that he never heard of that, he said that if the two pumps comes on at the same time the pressure will drop.
    Thanks.
  6. speedbump
    Jul 15, 2005
    Riverview, Fl.
    You mean you want to have two pumps pulling from the same suction line. Am I to assume you have two jet pumps now and want to add a third?
    bob...
  7. ts
    ts New Member
    Feb 21, 2005
    Yes, I will like to have two pumps on the same suction from the well, the current one and this new sprinkler pump I want to buy. The other pump is, I think a jet pump, it has a pressure switch, takes water from the holding tank thru the softner and into the house. The well pump does not have a pressure switch, I don't know what it's call.
    thanks
  8. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    Two pumps on the same pipe from the well is asking for trouble becuase they will almost certainly have two different characteristics and one will rob the other.
    You have a holding tank. Holding tanks are often installed because the well has limited capacity. A better solution, if you want a separate irrigation pump, is as follows.
    1. Well pump discharges to the holding tank, using a float switch in the holding tank as control. You should also have some kind of control to prevent the well pump from pumping the well below the inlet, which could damage the well pump.
    2. The pump to your house, with suction from the holding tank, can work as is.
    3. The irrigation pump can be connected to the holding tank. Since the water is supplied from the tank, the pumps won't "rob" each other. If you have a 2" outlet from the holding tank, you can connect both pumps to that pipe. You should have a full port ball valve on the suction side of each pump to permit one pump to be serviced while the other is still operating.
    4. You should have "Safety float switches" in the tank as follows.
    a. One at the lowest level from which you want to pump water, to lock out the house pump if the water gets too low. This protects the pump.
    b. One at a higher level to prevent the irrigation pump from pumping you out of household water. This should be at a level that you want to maintain as a household reserve; not to be used for irrigation.
  9. ts
    ts New Member
    Feb 21, 2005
    Thanks for the information
Similar Threads: Using same
Pumps and Tanks Well Forum & Blog. Water is life. Using correct Poly pipe ? Yesterday at 8:47 AM
Pumps and Tanks Well Forum & Blog. Water is life. Why Is Pump Gallons Per Minute Rating Important if You are Using a Pressure Tank? Jul 14, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Need filter for a filter head mounted housing Jan 4, 2016
Pumps and Tanks Well Forum & Blog. Water is life. using CSV, how long should it take to reach cut-out pressure Sep 15, 2015
Pumps and Tanks Well Forum & Blog. Water is life. frankin 1hp pump not starting up, but using electricity Jul 5, 2015
