Using ROMEX® to feed subpanel, do I have to derate from Table 310.15(B)(6)
Discussion in 'Electrical Forum discussion & Blog' started by Mr_Magoo, Sep 23, 2008.
  1. Mr_Magoo
    Mr_Magoo New Member
    Mar 8, 2008
    I want to put a subpanel in the garage. According to Table 310.15(B)(6), I would need #4 Copper for a 100amp subpanel. Is this table for individual conductors in conduit or can you use ROMEX® to feed the subpanel at 100amp? The reason I ask is I read that when using ROMEX® you had to derate the THHN in ROMEX® to the 60*C rating.
    Thanks,
    Mike
  2. Mr_Magoo
    Mr_Magoo New Member
    Mar 8, 2008
    Further research has indicated that I do need to derate when using NM.
  4. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    Do just a bit more research and you will see that Table 310.16 must be used also
  5. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    You are not "derating" anything. NM cable simply must use the 60 deg C column.
    IF you did need to derate the cable you would do so from the actual insulation temperature column which is 90 deg C.
  6. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    As already mentioned, you cannot use table 310.15(B)(6).
Similar Threads: Using ROMEX®
Electrical Forum discussion & Blog Adding Circuits using ROMEX® vs. AC cable Feb 14, 2009
Electrical Forum discussion & Blog Using "MC Lite" (aluminum jacket) cable connectors Oct 13, 2016
Electrical Forum discussion & Blog Using Multi Conductor wire for heavy load May 9, 2016
Electrical Forum discussion & Blog 240v circuits and using a white wire as a hot Apr 24, 2016
Electrical Forum discussion & Blog Using Madison Clips with new work metal box Mar 14, 2015
