Using Pex on radiators for steam.
Discussion in 'Boiler Forum' started by Clevdale, Nov 28, 2009.
  1. Clevdale
    Clevdale New Member
    Nov 28, 2009
    Michigan
    Is there a type of pex that can be used on radiators for a two pipe steam system? I am going to put back several radiators that had been removed from a house I recently bought and I wanted to use pex to pipe them in if possible. I have a brand new steam boiler and need to heat the whole house not parts of it as the previous owners tired to do. Any help would be gratefully appreciated even if it is a no you can not use pex.
  2. jadnashua
    Pex cannot be used for steam...the max temp liquid is usually around 180-degrees, and steam would be much hotter than that. Plus, you normally have a larger pipe than generally available with pex.
  4. Clevdale
    Clevdale New Member
    Nov 28, 2009
    Michigan
    Sorry to hear but needed to know
    Thanks for the info about the pex. I am going to be placing them back in a hall and upstairs bedroom and possible the living room the feeds are all still there but they have been capped and the risers are gone. What do you all think would I be better of sticking with the old used radiators or get the new style ones? I have seen several new very thin and set close to the wall with several colors choices, but will they radiate the heat as well as the old ones do?
  5. hj
    radiators
    If the "square footage" is the same they will heat the same, but even if they are thinner the pipes will still have to stay where they are so the radiators would probably be further away from the wall than the old ones were.
Similar Threads: Using radiators
Boiler Forum Safely shut off steam radiators? Only using front of old building Feb 24, 2013
Boiler Forum New Boiler causing chimney condensation Jan 27, 2017
Boiler Forum Fill and expansion tank position when using a Spirotherm quad-2 Jan 1, 2016
Boiler Forum Beckett AFG - Causing Faint Smell Aug 16, 2014
Boiler Forum Using boost temperature and outdoor reset settings on Lochinvar Knight Dec 28, 2012
