Using CLR to remove buildup from cast iron drain pipes???
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by supermattthehero, Jul 27, 2011.
  1. supermattthehero
    supermattthehero New Member
    Oct 13, 2009
    virginia
    A few months ago, I had cut out my bathtub trap and replaced it with a tubular plastic one. The old one was cast iron, and about 50% blocked with a rusty-buildup on the bottomside of the pipe. I was wondering if anyone has tried using CLR to fix a slow cast iron drain, thinking that it might be able to remove the rusty buildup inside (house is 55 years old)?
    I e-mailed Jelmar and they had this to say:
    "CLR, Calcium, Lime and Rust is safe for use in copper plumbing and septic systems and does remove rust so pouring it down your drains could help if the cause of the slow drains was in fact a rust buildup. The effectiveness of CLR comes with contact. I’m not sure if pouring it down your drains would have the 2 minutes of contact that usually takes to remove a buildup."
    Thanks.
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    I suppose it might work but in many cases, once the rust goes it leaves a hole behind.
  4. jadnashua
    If there's that much rust, the integrity of the pipe and fittings is in question...I think it's time for more mechanical work (remove and replace) rather than chemical.
  5. hj
    IF CLR would work, which is not a given and also probably not likely, it could take YEARS to dissolve the buildup, NOT minutes.
  6. supermattthehero
    Oct 13, 2009
    virginia
    This was the pic when I cut out the old pipe. I would imagine the rest of the pipes in the house look similar. Pipe integrity seems OK. Does this look like rust build-up? The gunk has sort-of the same texture as "astronaut ice cream" - dry and crumbly.
  7. hj
    If it come loose, it was not rust. If you have to use a hammer and chisel, then it IS rust.
Similar Threads: Using remove
Plumbing Forum, Professional & DIY Advice Using Cast Iron Flange Replacement as "removeable" flange for PVC dwv Jul 16, 2011
Plumbing Forum, Professional & DIY Advice Using Rainfall Shower Head Jan 28, 2017
Plumbing Forum, Professional & DIY Advice Anyone using the Basement Watchdog Big Dog? Jan 18, 2017
Plumbing Forum, Professional & DIY Advice Toilet venting using wet and dry combination Jan 15, 2017
Plumbing Forum, Professional & DIY Advice Using a recirculation pump to prevent freeze up of a supply line. Dec 12, 2016
