Using a Floor Sink for a utility sink drain
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Mr_Magoo, Aug 30, 2008.
  1. Mr_Magoo
    Mr_Magoo New Member
    Mar 8, 2008
    My mechanical room has a floor sink with 2" pipe, a trap, and vent. It was installed to be a condensate drain. It goes to the septic.
    I am considering putting a small utility sink in the mechanical room and would like to plumb the utility sink into the floor sink without busting any concrete. I don't think I should put a trap in the utility sink drain line as the trap in the floor sink would serve the utility sink. Is my plan going to be legal?
    Thanks,
    Mike
  2. Master Plumber 101
    Master Plumber 101 In the Trades
    Aug 11, 2008
    Wisconsin
    Mike, when you say floor sink, do you mean floor drain? There is a difference in a floor sink and a floor drain. If it is a receptor, not a floor drain, I would say it is questionable. The only thing is how far you can run the waste to the receptor. Depending upon which code you follow.
  4. Mr_Magoo
    Mr_Magoo New Member
    Mar 8, 2008
    It is definitely a floor sink about 10" square by 12" deep. I put the sink in myself before we poured the concrete. Putting a utility sink in the mechanical room is an idea that came up later. We are governed by UPC. How far can I run my drain line from the utility sink?
    BTW, don't commercial kitchens have sink drains like this?
    Thanks,
    Mike
  5. Master Plumber 101
    Aug 11, 2008
    Wisconsin
    Commercial K.S. or food prep sink can use this application. I can't tell you what the upc say's but what I'm governed by is the following.
    For a L.T. you can't dump into a floorsink. Exp. is you can't dump one fix to another. Would it hurt anything probably not. If you are getting it inspected you should do it right. Your code may say something different.
Similar Threads: Using Floor
Plumbing Forum, Professional & DIY Advice Using Rainfall Shower Head Jan 28, 2017
Plumbing Forum, Professional & DIY Advice Anyone using the Basement Watchdog Big Dog? Jan 18, 2017
Plumbing Forum, Professional & DIY Advice Toilet venting using wet and dry combination Jan 15, 2017
Plumbing Forum, Professional & DIY Advice Using a recirculation pump to prevent freeze up of a supply line. Dec 12, 2016
Plumbing Forum, Professional & DIY Advice Using heat cable on PVC drain???? Dec 4, 2016
