Sprinkler
Hi, I have an underground 25mm (1" external dia.) pipe running from the well to the house, and I'd like to connect a pump which has a 1,25" outlet. Is it possible to use a reduction adaptor ( 1,25" to 1") next to the pump? Or alternatively, I was thinking of installing the same diameter (1,25") pipe from the pump top the top of the well, and then install the reduction to 1". Would either of these solutions put a lot of extra work or wear out the pump? Thank you.
