Using 1 1/2" drain pipe in condo
Discussion in 'Shower & Bathtub Forum & Blog' started by andywc, Nov 4, 2005.
  1. andywc
    andywc New Member
    Nov 4, 2005
    I want to replace the bath with a walk-in shower in my Condo. This will re-use the drain as a floor drain for the shower.
    The existing piping in 1 1/2" and I cannot change that as that would require touching the central drain and my downstairs neighbors ceiling, and the board will not allow that.
    In Arlington County, Virginia the IPC 2000 has to be followed. This states that the shower waste outlet has to be 2" (417.3). However, code 709.1 says that I can use a 1 1/2" trap with a shower.
    Would it be code compliant to use a 2" shower drain connected to a 1 1/2" trap and drain pipe?
    Anyone know or had this problem?
  2. jeffreyhel
    jeffreyhel New Member
    Nov 4, 2005
    I can't speek for IPC since here in NJ we use a different code but here in NJ it MUST be 2".
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I'm just a DIYer, but it is my understanding that you should never reduce the size of a drain. In other words, stay 1-1/2" all the way to the main drain. Ideally, a shower should have a 2" drain, but in reality, many showers work just fine with 1-1/2". This fact of course will not impress a code inspector, so you should check with your local authorities to see what they will/will not allow.
  5. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    Distance to the stack - ??
    How far to the stack, Andy? This will determine how much the 1 1/2" would be slower to drain than a 2" pipe. It will work.
Similar Threads: Using drain
Shower & Bathtub Forum & Blog Using existing tub water/drain for sink Oct 17, 2009
Shower & Bathtub Forum & Blog reusing antique overflow coverplate with new drain? Nov 15, 2006
Shower & Bathtub Forum & Blog Using sink drain for new shower? Sep 13, 2006
Shower & Bathtub Forum & Blog Repl shower head using fpt coupling--Plan C:can't catch a break Jan 31, 2017
Shower & Bathtub Forum & Blog Bathroom faucet water leak - faulty faucet using both lines Sep 2, 2016
