Used Kinetico
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Mike3951, May 12, 2010.
  1. Mike3951
    Mike3951 New Member
    May 12, 2010
    Oregon
    Hello,
    We live in Albany, Oregon, we have had our water tested and it is very high in sulfer and iron in our well. We were given a Kinetico water filter package(salt container and 2 presure tanks)
    My question is could you tell us if it is worth setting this system up (cost) or should we look into buying a new one.
    Thanks,
    Mike
  2. hj
    Well, I would never BUY a Kinetico system, but since you have it, once you install it, replacing it with something else at a later date would normally be fairly simple.
  4. Gary Slusser
    Retired
    A softener won't do anything for H2S odor.
    What do you mean 2 pressure tanks?
  5. BevinsWater
    BevinsWater New Member
    Aug 31, 2010
    oregon
    advice for you.
    Yes it would be worth getting the Kinetico installed. Kinetico is a great brand. This is a fact. Of course people have different types of water issues and a Kinetico might not be ideal. However...Kinetico systems work much better than your standard water softener. They use a great media filter to help filter bad water. iron ect. Macrolite. its very good. The us military invented the technology. non electric and unlike most filter systems it always has water on hand where most do not because they must flush out and cannot give you filtered water 24 hrs a day. you may already know this. and i havent really expressed all the benifits of a kinetico. There are other options that work well too. The guy who said Kinetico is any good...(I wouldnt base any opinion from that).
    usually people who do not like this brand(not that many)... should have issue with the salesman who sold them the wrong equipment..which wasnt ideal for there water needs.
    Kinetico will remove some of the odor but is not made for that. If you have a bad odor problem along with the iron...I would recommend a couple add ons to the system. A good inline filter would help out alot.
    Sounds like to me you should try the kinetico out. there are plenty of families out there that wish they would have went with kinetico. There are other systems that work well. water usage is important to consider when shopping for the right system. properly sized filter that will keep up with your usage.
    Kinetico is good for sulfur & iron removal.
    have you got your filter system all hooked up yet?
Similar Threads: Used Kinetico
Plumbing Forum, Professional & DIY Advice Clogged toilet caused major flooding Jan 14, 2017
Plumbing Forum, Professional & DIY Advice Whole House Water Filter HELP...super confused Dec 28, 2016
Plumbing Forum, Professional & DIY Advice Where can backwater/backflow valves be used in a building? Nov 29, 2016
Plumbing Forum, Professional & DIY Advice How to sell an unused plumbing item? Jul 17, 2016
Plumbing Forum, Professional & DIY Advice Flushing Toilet, Coming Through Shower Drain... Only When A Lot Of Water Is Used Apr 25, 2016
