Use Chlorine (Charcoal) filter in Whole House Sediment Filter Housing ??
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by kstuart, Mar 3, 2011.
  1. kstuart
    kstuart New Member
    Nov 23, 2005
    Central Coast CA
    The previous house owner had installed a water softener and then removed it.
    The water softener was replaced by a flexible tube, and everything has 3/4 inch connections.
    It would be very easy install a G.E. or equivalent Whole House Sediment Filter Housing where the water softener used to be - but I don't have a sediment problem, instead our water is very chlorinated.
    I would like to replace the chlorine filters at faucets and showers with one for the whole house.
    But, the whole house housing is clearly marked "sediment" and while the chlorine filters have the same length and the exact same rubber ends, they are indicated only for the under-sink units.
    So, I was wondering if I will have some sort of problem by putting one chlorine filter for the whole house - since for some reason, it is not indicated.
    Thanks for your experienced advice !
Similar Threads: Chlorine (Charcoal)
Plumbing Forum, Professional & DIY Advice Chlorine tablets well water once per year? May 30, 2016
Plumbing Forum, Professional & DIY Advice Can I fix mild odor in hot water with chlorine injector? Dec 12, 2014
Plumbing Forum, Professional & DIY Advice Chlorine removal POE vs POU Jan 28, 2013
Plumbing Forum, Professional & DIY Advice Plumbing problems after shocking well with chlorine! Help Apr 25, 2012
Plumbing Forum, Professional & DIY Advice Chlorine water treatment system Feb 25, 2006
