Urinal valve question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by hampton roads Virginia, Jun 28, 2010.
  1. hampton roads Virginia
    hampton roads Virginia New Member
    Feb 27, 2007
    At our community pool we have an stinky urinal. Someone shut off the water flow screw because it would just run continious.
    I took off the top cover and pulled the diaphram. I'm assuming it needs a new Sloan diaphram? I'm not solid enough on how these direct pressure systems work though. I can rebuild a home toilet blindfolded.
    Any educational links, answers, advice , is appreciated ;)
  2. jimbo
    jimbo Plumber
  4. nhmaster3015
    nhmaster3015 Master Plumber
    Jul 30, 2008
    Teacher
    The granite state
    I generally rebuild the entire valve. Sloan has a kit with all the new stuff in there. That said, you really should check the pressure and the volume at the fixture. Many of the old Sloan's need a lot of water to operate properly.
Similar Threads: Urinal valve
Plumbing Forum, Professional & DIY Advice Is 1/2 inch PEX okay for a typical urinal flush valve? Aug 30, 2015
Plumbing Forum, Professional & DIY Advice Piston valve vs Diaphragm valve for urinal May 30, 2012
Plumbing Forum, Professional & DIY Advice urinal flushvalves Sep 23, 2008
Plumbing Forum, Professional & DIY Advice Low flow urinal from American Standard and dual flush valve from Sloan. Jan 17, 2007
Plumbing Forum, Professional & DIY Advice urinal stop valve question Aug 29, 2006
