urinal stop valve question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by rcav8or, Aug 29, 2006.
  1. rcav8or
    rcav8or In the Trades
    Aug 5, 2006
    Electronics Technician
    Oxford, IN, home of Dan Patch
    This may sound silly, but inquiring minds want to know!
    I am installing a urinal in my pole barn. I have all the plumbing inside the bathroom interior walls except a short run to the urinal, which was behind the wall (well-insulated) so I don't have to heat the whole barn, just the bathroom (7 X 7).
    I had the urinal pluming go through the wall for a foot, then back out to the stop valve. Of course, THAT'S the place the solder joint leaked!! (all copper). Instead of doing it like that, I'd like to go ahead and keep ALL the plumbing inside the interior walls, so I can easily get to the pipes anytime I need to. The problem is the stop valve would have to be "vertical" instead of horizontal, as is normally the case.
    Flushometer is a Sloan Optima G2 automatic flush.
    Question is, can I turn the stop valve 90 degrees, so that the inlet either faces up or down, instead of to the rear, which is normal? I can't think of any problems doing it that way, but would like the "pros" opinions.
    Thanks in advance!!!
    Roger
  2. Winslow
    Winslow Plumber
    Dec 30, 2005
    Hawaii
    it will work fine that way
  4. rcav8or
    Aug 5, 2006
    Thanks
    Thanks! That's what I thought, but wanted a 2nd opinion.
    Roger
Similar Threads: urinal stop
Plumbing Forum, Professional & DIY Advice Is 1/2 inch PEX okay for a typical urinal flush valve? Aug 30, 2015
Plumbing Forum, Professional & DIY Advice Urinals - Slow draining Dec 9, 2014
Plumbing Forum, Professional & DIY Advice Urinal drain rough-in Apr 24, 2014
Plumbing Forum, Professional & DIY Advice Urinal leaks at spud Apr 24, 2014
Plumbing Forum, Professional & DIY Advice Urinal, residential: Looking for advice Apr 6, 2014
