Urinal Flush Valves
Discussion in 'Toilet Forum discussions' started by plumberj, Jul 4, 2013.
  1. plumberj
    plumberj New Member
    Jul 4, 2013
    NY
    I am looking to replace an existing manual flush valve which sits above an AS Washbrook urinal with a set of parts which include a sensor and a solenoid valve to control the water to flush the urinal - a kind of do it yourself automatic flush valve. Has anyone tried this before and if so what are the likely issues with codes? Basically I am looking to source parts from a home improvement store so I can swap out the manual valve.
    Thanks in advance for your thoughts! :)
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    What make valve do you have?
    John
  4. plumberj
    plumberj New Member
    Jul 4, 2013
    NY
    Hey John, it's a Sloane. So I want to remove that and replace with parts which include a sensor so I can effectively create my own automatic sensor-activated valve.
    Thanks.
  5. plumberj
    plumberj New Member
    Jul 4, 2013
    NY
    Thanks.
  6. johnjh2o1
    Aug 9, 2009
    Retired
    Florida
  7. jadnashua
    Trying to build your own means fighting the certification agencies for both the plumbing bits and potentially, the electrical bits...much better to buy one that has already jumped those hurdles.
  8. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    Especially when you can get a Sloan retrofit kit online for less than $250.
  9. plumberj
    plumberj New Member
    Jul 4, 2013
    NY
    Hi Jim,
    That's useful, thanks. You and johnjh2o1 and wjcandee all seem to agree on the retrofit approach and I can see the advantage of that in terms of it being pre-approved etc. which sounds sensible.
    Just to take it the full course, with a build-your-own version, which certification agencies would you need to speak with?
    Best.
  10. jadnashua
    Electrical, UL, plumbing parts, take a look at the stickers on a stock valve in the store. A plumbing inspector could give you all sorts of grief (or not) if it's not something out of the box that has already been approved. To get those approvals is not inexpensive, and not something you'd likely want to do as a one-off. But, if you can build it out of parts that have already been approved, you have a chance with the inspector.
Similar Threads: Urinal Flush
Toilet Forum discussions Upgrade For 90 Degree Urinal Flush Valve? Feb 7, 2013
Toilet Forum discussions Final Specs for Watersense flushing Urinals Oct 15, 2009
Toilet Forum discussions Urinal flushmeter valve Nov 12, 2008
Toilet Forum discussions 1930's urinal tank? Aug 13, 2016
Toilet Forum discussions Waterless urinal venting Nov 14, 2015
