Upstairs don't flush, downstairs does
Discussion in 'Toilet Forum discussions' started by catlind, Feb 24, 2005.
  1. catlind
    catlind New Member
    Feb 24, 2005
    Please help quickly.
    We have two toilets upstairs that are currently not flushing. At first there seemed to be a slow flush with lots of bubbles, then they stopped flushing all together.
    The main floor of our residence has a "powder room" and this toilet does not seem to have a problem.
    Please advise what this may be and what we can do.
  2. hj
    You either have two toilets that need to be serviced, or an unusual situation where the pipe going up to the toilets is obstructed before it connects to the main line going to the powder room.
  4. catlind
    catlind New Member
    Feb 24, 2005
    Is this normal?
    Thanks for the quick response.
    Husband took off toilet in master bath and snaked a few times. First time when he brought up snake it had wax on it. He knows that none of the wax ring came off when he first removed toilet because he would have seen it at the bend in pipe. He snaked a few more times and brought up a little bit of waste debris. We then flushed other toilet upstairs a few times. On the third flush, it did not seem to want to flush, then it went down in a whoosh and there was a loud noise from the pipes in the wall. Also the downstairs toilet splashed up some water.
    Now the guest toilet seems to flush with no problem. still need to set the master to see if it flushes fine.
    Question is this....when the guest toilet upstairs is flushed the powder room toilet water moves slightly. Is this normal or do we still have a problem somewhere in the line?
    Thanks again!
  5. jadnashua
    Chatter here relates that some less than quality workmen use the toilet drain as a waste dump, and could have contained drywall compound, wood chunks, and god knows what. SO, that may be what was causing the problem, which you've now cleared out.
Similar Threads: Upstairs don't
Toilet Forum discussions What is leaking if ceiling below toilet shows water damage, but no water leaks show upstairs? Jul 15, 2016
Toilet Forum discussions flush the toilet upstairs and a loud noise Oct 20, 2013
Toilet Forum discussions Basement toilet splashes when upstairs dishwasher or clothes washer are draining May 17, 2010
Toilet Forum discussions upstairs toilet damages drywall when overflowing Dec 18, 2009
Toilet Forum discussions Toto ADA/upstairs downstairs questions Aug 26, 2009
