Upstairs Cleanout location
elwood22165
Where do most plumbers place cleanouts in 2 story houses. Do you put a test Tee behind an access panel .
thanks for any replies.
cleanouts
We don't usually install them there, unless there is a horizontal pipe below the floor. A vertical pipe seldom stops up, so the cleanouts are just needed on the lower lever before the pipes turn horizontal.
elwood22165
horizontal run
There will be about 10 feet of horizontal run on a 3 inch line> what would be the best place to put a cleanout and how. in a wall with an access cover?
SRdenny
Plumbing Contractor
SF Peninsula
Yes. A convenient wall, preferrably an exterior one (so any maintenance mess stays outside), with a cover would work nicely.
