upstairs bathroom drain/vent question
Discussion in 'Shower & Bathtub Forum & Blog' started by Bobawho, Dec 30, 2006.
  1. Bobawho
    Bobawho New Member
    Dec 30, 2006
    maint tech
    Illinois
    Hello all...I'm in the process of expanding an upstairs bathroom that I gutted with the exception of the main stack drain/roof vent..In one corner of the room i'm installing a custom neo angle shower..directly next to that along the same wall a corner jetted drop in tub.Both of these units are on the opposite wall as the main drain, which is about 12 feet away the toilet and sink being close to the main drain....My question is.Their is no wall in the design between the tub and shower so my vent line has be ran horizontally to either an inside or outside wall before rising up into the attic to tie back into the roof vent..Can the vent line be either tied in either up stream or downstream from the traps and do I need a separate vent for both tub and shower.Also what type of fitting is best to connect both drains to the 2 inch drain line? Thank you very much for all answers..Bob
  2. Cass
    Cass Plumber
    Nov 12, 2005
    They each need their own vent. How far from the traps will the vents be?
  4. Bobawho
    Bobawho New Member
    Dec 30, 2006
    maint tech
    Illinois
    upstairs bathroom tub/shower vent and drain ?
    the walls which I will be venting upward are about 5 or 6 feet from the traps depending which way I route them
Similar Threads: upstairs bathroom
Shower & Bathtub Forum & Blog Inconsistant hot water to one of two upstairs bathroom showers. Feb 5, 2011
Shower & Bathtub Forum & Blog Can I run an upstairs vent downstairs, tying into existing vent? Jan 10, 2016
Shower & Bathtub Forum & Blog no hot water /pressure/ upstairs shower only Nov 7, 2009
Shower & Bathtub Forum & Blog New Upstairs tub installation Oct 2, 2008
Shower & Bathtub Forum & Blog Upstairs tub drain leak Jun 11, 2008
