Upstairs Bathroom Addition
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Chris Mashburn, Jan 8, 2008.
  1. Chris Mashburn
    Chris Mashburn New Member
    Jan 8, 2008
    I am researching using a Saniflo macerator unit in a second floor bathroom addition.My house is on a slab foundation so there is no easy way to access a large drain line.I have a 2 inch Vent pipe which runs vertical through the outside wall of my first floor kitchen and then thru the attic and out the roof.The vent pipe has a cleanout plug on the outside of the house so I removed the plug and flowed water into the hole and confirmed it will drain.Since the discharge on the macerator is 3/4 inch could I discharge into the 2 inch vent pipe in the attic?
  2. jadnashua
    If there was a blockage, all that s*** would get pumped into your sinks, tubs, toilets, etc. downstairs. If you ran it down and joined the drain down on the first floor, say maybe from a sink, it might work. You'd still need to run a vent for the pump - you could joint into the vent line in the attic, but not with waste.
  4. construct30
    construct30 New Member
    Jun 16, 2007
    NorthWest PA
    You would be turning the vent stack into a wet vent IRC says no wet venting between floors, if I understand you correctly, no for IRC/IPC.
  5. Chris Mashburn
    Jan 8, 2008
    Thanks for the advice.Could I discharge the saniflo macerator into a washing machine drain.Can you put a "S" trap on the washing machine drain to keep the smell below that level.
Similar Threads: Upstairs Bathroom
Plumbing Forum, Professional & DIY Advice Adding an upstairs bathroom, double lavs in Master Sep 18, 2013
Plumbing Forum, Professional & DIY Advice Backup in upstairs bathroom Dec 26, 2008
Plumbing Forum, Professional & DIY Advice new bathroom upstairs Apr 27, 2007
Plumbing Forum, Professional & DIY Advice New upstairs bathroom advise Sep 29, 2006
Plumbing Forum, Professional & DIY Advice Smell after upstairs shower in Downstairs bathroom???? Nov 28, 2005
