Uponor PEX connector?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jerome7, May 13, 2013.
  1. jerome7
    jerome7 Member
    Nov 14, 2010
    95020
    Hi all,
    Could you please tell me what kind of connector is pictures? Is this PEX?
    Thanks
  2. jadnashua
    Looks to me to be a transition fitting. It's first soldered to the copper, then you attach the PEX. The plastic pipe should have some markings on it to identify the maker and the type. They're usually repeated all along the entire length of the roll of tubing. It might be Wirsbo/Uphonor, as that's not a crimp connection (Wirsbo/Uphonor use an expansion system with a reinforcing ring). I don't deal with the stuff enough to be sure, though.
  4. jerome7
    jerome7 Member
    Nov 14, 2010
    95020
    Yep. I was curious about that ring that keeps the plastic tube securely tighten to the copper. I haven never seen this kind before.
  5. jadnashua
    Pex tubing has 'memory'. There are basically three ways to make a pex connection: a compression fitting like a Sharkbite or one that uses a compression ring and a nut; a barbed fitting and a crimp ring; an expansion system that uses a (larger diameter barb) where the tubing is expanded with a tool, slipped over the barb, then left to collapse back onto the barbs to make the connection. They add the compression ring on top of the tubing to force it to have more force when it collapses (they are both expanded with the tool prior to sliding it over the fitting). I'm still not sure exactly what you have - it could be one of the first types where you just push the tubing into the fitting (those often have an o-ring to make the seal, then something to grip or hold the tubing in place).
  6. Terry
    Aug 17, 2004
    That is Uponor PEX, (previously Wirsbo) It's the brand that I use.
    It uses an expansion tool.
  7. ssweb
    ssweb New Member
    Dec 23, 2016
    Maine
    This seems as good a place to ask this question,
    Once one of these Uponor fittings is set. Is it ok to turn the pipe in the connector. In this example if I took a pipe wrench to the pipe and turned the pipe in the current position would the seal get broken?
  8. Terry
    Aug 17, 2004
    Maybe and maybe not.
    I can turn them before the snug up. I haven't tried after that.
  9. ssweb
    ssweb New Member
    Dec 23, 2016
    Maine
    In this case I was able to the pipe after it was snug. I am curious if this might be a problem later on.
    This is a virgin use of these connectors and PEX.
  10. Terry
    Aug 17, 2004
    If it's not leaking now, I think you're good.
    I just looked at a water heater leak on the incoming supply, CPVC. It came apart in my hands. I will be repiping that in PEX.
    [​IMG]
  11. ssweb
    ssweb New Member
    Dec 23, 2016
    Maine
    Thanks for your input.
Similar Threads: Uponor connector
Plumbing Forum, Professional & DIY Advice Uponor PEX with non-ProPEX fittings Nov 1, 2016
Plumbing Forum, Professional & DIY Advice Replace Uponor Tee Jun 6, 2015
Plumbing Forum, Professional & DIY Advice Replacing Wirsbo Control Type 514 with Uponor A3031004. Feb 5, 2015
Plumbing Forum, Professional & DIY Advice Uponor Repipe Feb 5, 2015
Plumbing Forum, Professional & DIY Advice slant fin 80 vs uponor radiant flooring Jan 30, 2015
