Updating Very Old System Timer
Discussion in 'Irrigation / Sprinkler Forum' started by sobersgea, May 23, 2008.
  1. sobersgea
    sobersgea New Member
    Sep 13, 2006
    Does anyone know if I can buy/use a new sprinkler system timer for a very old system? Our sprinkler system was installed in 1991 with a Weathermatic timer. I would like to get a new timer with more programming options. I would like to be able to select a pre-set program and have only that program run. With the Weathermatic, if I set programs 1 and 2 and turn on the Valve Power, it will run through BOTH programs. There is no way to say run only program 1. I also wonder if the timer could be in the house instead of in the garage. Do they make remote controls so you could start the system while in the living room?
    Thanks,
    Sherry
  2. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    You can get the extra programming options with a Hunter SRC controller. Three different programs, each with their own schedules. Best of all, you can keep the controller in the garage, and connect their SRR receiver to the controller, and use the deck-of-cards-sized transmitter to operate it from inside the house, as long as there aren't masonry walls between the receiver and transmitter. Frame construction doesn't block the signals, but stone and concrete and metal will. Hunter also makes controllers with more features than the SRC, but compared to a 1991 controller, the SRC is more than enough.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Realize that a controller/timer does one thing. It sends an electrical signal to the valves to open them. The valves could care less what brand or complex programming option the controller has. In other words, any brand will work. It takes a hot wire from the controller to each individual valve and a common ground wire from the controller linked to each valve. You can go low tech or high tech as suits your needs and budget, but basically all a controller does is switch the zones on and off.
  5. sobersgea
    Sep 13, 2006
    Thanks for the information Wet_Boots. I looked up the Hunter and found a local distributor. I will contact them after the holiday. I like the idea of the remote. Just the "tune-up" the old system needs. :D
    Thanks again.
    Sherry
Similar Threads: Updating Very
Irrigation / Sprinkler Forum Is it necessary to turn on the sprinkler system at least once every season? Jul 9, 2011
Irrigation / Sprinkler Forum One zone every day, all other zones periodically? Jun 21, 2009
Irrigation / Sprinkler Forum Best type of drip emitters for very hard well water? Jul 27, 2008
