Update from Gen Resin Questions SST-60
Discussion in 'Water Softener Forum, Questions and Answers' started by Akpsdvan, Jan 22, 2010.
  1. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    When one uses a turbolator in a tank one can get more resin in that same size tank
    Say an 8x44 tank with turbolator I would put 1.0 cubic foot of resin, giving 10" of space between media and top of tank.
    I would also have the backwash rate down to 2gpm on such a unit.
    Now some may say that what I am doing is not right, but know this , I have been doing units this way for 20 years with 0 problems on units set up this way..
  2. Akpsdvan
    Dec 29, 2009
    Alaska
    I did not start this thread, but rather Townan did with the opening line of Update from Gen Resin Questions SST-60.
    I have no idea how I ended up replaying to it and ended up as the opening of the thread.
  4. Towman
    Towman Many Hats, few paychecks
    Dec 25, 2009
    sc Wisconsin
    Thought I would update everyone.
    I don't know if I should have added this as a reply or a new thread? Feel free to say so
    http://www.terrylove.com/forums/showthread.php?33856-General-Resin-questions
    I tried flushing the fouled softener to no avail.
    I decided to replace the resin with (sst-60) and replace the down pipe in the resin tank with a turbolator. This was not exactly recommended, but thought I might try it.
    I was surprised that resin tank had no gravel bed in it, I know you don't use one with a turbolator, but thought you had to have a distribution bed otherwise.
    There seemed to be a general consensus that I needed a bigger unit, but I will see how long this last.
    It is working very well and I am extremely happy with the outcome.
    If anyone decides to do something like this, I will say it is fairly easy. Just make sure the valve isn't bleeding hard water past the bed.
    Anyone with further thoughts are appreciated.
    Towman
  5. Bob999
    Bob999 In the Trades
    Jul 4, 2009
    Pennsylvania
    With smaller diameter tanks gravel is not required for underbedding and is frequently not used. That said it is always good practice to use gravel underbedding so long as you are not using a turbulator.
  6. Gary Slusser
    Retired
    A softener without a gravel underbed will have a higher pressure loss than a same sized softener with one.
    There is no downside to a gravel under bed other than the few dollars for the gravel and shipping. Most of my competition do not include a gravel under bed regardless of the size of the tank. They also don't use the same size tanks and therefore they don't get the resin manufacturers' suggested minimum of 50% bed expansion during backwash which ruins resin.
  7. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    I'm not your competition, but I always gravel underbed.
Similar Threads: Update Resin
Water Softener Forum, Questions and Answers HELP NEEDED! Update whole-house water filtration system (well water) Feb 6, 2017
Water Softener Forum, Questions and Answers Irrigation Well Iron removal system recommendations ***UPDATE*** Sep 10, 2015
Water Softener Forum, Questions and Answers Fine Mesh to Standard Resin question Today at 6:37 AM
Water Softener Forum, Questions and Answers Resin in Water Feb 12, 2017
Water Softener Forum, Questions and Answers Resin Cleaner? Jan 19, 2017
