Unusual stickiness?
Discussion in 'Toilet Forum discussions' started by kcodyjr, Nov 25, 2013.
  1. kcodyjr
    kcodyjr New Member
    Nov 18, 2013
    I.T. - UNIX server support
    Chelmsford, MA
    Latest in my long set of how-the-blazes questions.
    After I "go" there are invariably pieces stuck to the bowl. This has only been a problem since I moved here, and I'm not lazy about using the brush; every time I use the commode if I must. It is a low flow design.
    However, I'm standing there scrubbing back and forth for several minutes and these freshly-left pieces stubbornly resist.
    KIingons are one thing, but this is more like Kryptonite. Kraptonite? Seriously, they might be suitable as munitions.
    Should I suspect the water itself? Could the bowl have taken surface damage via contamination somehow?
    One of those $10 water test kits from Lowe's says my water is ever so slightly acidic, and ever so slightly soft, if that helps.
  2. jadnashua
    Long-term contact with acid can eventually etch the glaze on the toilet. It's not great for your pipes, either, and can leave copper stains, and discolor things. A new toilet would help for awhile, but would likely succumb to the same issues eventually. If you resolve the acidic water, look into one of the toilets with one of the optional super glazes...Toto calls theirs Sanagloss...it helps keep things from sticking.
  4. kcodyjr
    kcodyjr New Member
    Nov 18, 2013
    Chelmsford, MA
    If this has happened, wouldn't it take away the gloss?
  5. jadnashua
    The glaze has some thickness, so it starts really shiny like glass, then various stages of frosted, until you've eaten all of it off. Shiny is relative. How does it feel?
  6. kcodyjr
    kcodyjr New Member
    Nov 18, 2013
    Chelmsford, MA
    You mean I have to touch the surface of the toilet bowl?
    *twitch*
    I'll get back to you when I find some thin disposable gloves.
  7. kcodyjr
    kcodyjr New Member
    Nov 18, 2013
    Chelmsford, MA
    OK, I got over it and checked when it hadn't been used for awhile. It isn't rough, but there's a squeak to dragging my finger across it that isn't there around the rim. I can see texture in light reflecting off the bowl, but nowhere else. It's visibly just a little less glossy.
    Great. Just great.
    I don't think there's room in my plumbing closet for acid reduction, those things are huge, right?
  8. jadnashua
    Acidic water will etch glass with long exposure and pretty much all of the glazes are essentially glass based with potentially other stuff for color or who knows what. I've never tried it, but a good coating of one of the high-tech nano particle car waxes might solve the problem for awhile.
  9. kcodyjr
    kcodyjr New Member
    Nov 18, 2013
    Chelmsford, MA
    Waxing the toilet bowl. That's a charming thought. I'd never live it down. Still, it might work...
  10. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    Jim's already got you running your finger inside the toilet bowl, so you're already almost there! :)
Similar Threads: Unusual stickiness
Toilet Forum discussions Question on Aquia II install and unusual closet flange Mar 11, 2016
Toilet Forum discussions Need unusual toilet with 20" rough-in Oct 25, 2013
Toilet Forum discussions Help, Toilet with unusual requirement for wall heater May 24, 2013
Toilet Forum discussions Unusual Alternating Toilet Flushing Pattern Jul 1, 2011
Toilet Forum discussions unusual toilet tank - need info please Dec 27, 2009
