Hi I am renting out a space with a bathroom that has a tub with shower installed above. The enclosure is covered with tile. Water was getting onto the floor-- it hits the wall at the end, runs to the outside of the tub, and from there onto the floor. So I decided to replace the shower curtain with sliding glass doors.
The guy I had install it (trying to save myself trouble) couldn't deal with the un-plumb tub problem. The walls might be out of plumb too. (It's a 100-yr old house that has settled some). He left it with the doors all askew and when closed there is a gap at bottom thus countering the very reason for installing the doors in the first place.
Question: any tricks for re-doing it right, which would require variable-depth shimming at the sides and bottom? Ace hardware sold me some plastic shims and wide flat caulking tape to hide them. This is going to make for a pretty un-professional installation that is prone to problems, I suspect, so I haven;t done it. I searched online for shower enclosure shimming but didn't find anything.
I will no doubt also have to plug up the holes he drilled to install the frame, and drill new ones. Do I just fill the old ones with grout?
One idea I had was to lay tile along the tub itself, and use a variable depth tile-set material from one end to the other. But is there setting material that will withstand so much moisture creeping underneath?? And will it stick to porcelain? And will it look decent when finished??
Or should I just pull out the tub and use a tub-enclosure? That might keep water from going downstairs for sure and save me a lot of trouble in the long run. It would eliminate the ugly-caulking around tub problem too.
When I bought that house I re-did the tub enclosure walls, used cementitious, etc; but the part behind and below the tub might very will be rotten, since some of the part above was. (that was 1995 or so).
Any brilliant ideas based on experience with out of plumb tubs and bathroom walls would be gratefully received!
