Unknown rubber washer with my Drake II (see pic)
Discussion in 'Toilet Forum discussions' started by MandK, Apr 2, 2012.
  1. MandK
    MandK New Member
    Mar 15, 2012
    Riverside CA
    Hi Again,
    This came with my Drake II, but have no idea what it's for and it's not shown in the parts list. Only (1) was included.
    Has anyone seen this?
  2. Hackney plumbing
    Hackney plumbing Homeowner
    Jan 6, 2010
    Alabama
    Thats a cone washer for the water line connection to the ballcock. You dont need it if you use the ugly stainless braided supply line.
  4. MandK
    MandK New Member
    Mar 15, 2012
    Riverside CA
    OK. Thanks.
    I'm using braided because I had one in the garage. What does a good looking supply line look like?
  5. Hackney plumbing
    Jan 6, 2010
    Alabama
    Plated copper tube bent with a bender.
  6. Spacepod
    Spacepod New Member
    Mar 30, 2012
    Socal
    I noticed this too. Had this washer leftover but I am using a new stainless braided supply line (which I think looks great). :)
  7. Terry
    Aug 17, 2004
    I think most manufacturers include the rubber washer in case a solid riser is being used.
    I used to use a lot of the closet risers with the flat end; those wouldn't use the washer. I find that a flexible supply line is a bit quieter on the refill. It seems to isolate the vibration. And I'm all about keeping things quiet.
    The washer is nice though if you're using solid tubing without the end.
  8. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Obviously there are differences in opinion about solid tubing and flex tubing. It appears the flex tubing with the braided stainless steel mesh is preferred by most, especially DIY.
  9. jadnashua
    A solid line probably is better, but it does take more skill and time. In many installations, it's hard to see the silly thing, and a flex hose will take an occasional knock from a broom or mop probably better than a solid connection, but it would have to be fairly hard.
Similar Threads: Unknown rubber
Toilet Forum discussions Unknown toilet Sep 4, 2007
Toilet Forum discussions Seemingly Unknown Shanks Brass Cistern? May 3, 2007
Toilet Forum discussions Toto leaking what are these 2 rubber things disentegrating Dec 7, 2015
Toilet Forum discussions Korky 528 rubber pad on float arm Sep 26, 2015
Toilet Forum discussions Can't locate TOTO Original Flappers or at least the rubber seal gasket. Feb 10, 2015
