Archibald Tuttle
i have not encountered this problem before and i've been through hundreds of toilets. the universal flapper doesn't stay up when flushed. i worked with the chain length from the flush handle to make sure i was lifting it as far as possible but it slams shut immediately upon releasing the handle.
i have seen that fluidmaster makes a 5051 with a float on the chain that you set to accentuate the float of the flapper. i've never needed that before.
i can't really tell. i don't think the overflow tube is closer to the actual opening. i can't figure out why the air in the flapper itself doesn't serve the normal function.
i tend to view this kind of problem as a water saving device, but the tenant i'm servicing doesn't want to invest that opportunity costs to hold the handle for the extra 10 seconds to get a full flush. i can't say in this fast paced world that i really blame her and i'm perplexed as to what phenomenon might make this occur where i usually don't have problems with these universal flappers.
thanks
brian
thanks
brian
