Unique Tub drainage configuration
tomtbone
tomtbone in Boston
www.ottoplanet.net
We are remodeling our bath and putting in a new tub while moving it 6" or so. The issue I am running across is that directly below the overflow is the large horizontal cast iron pipe and directly below the drain is a joist. Can someone tell me if this type of configuration would work to attach a p-trap?
Previously, the tub was 6" back, and a drum-type trap was attached directly to the drain not overflow.
Redwood
you can get a drain in shoe type drain and have the p-trap directly under the drain.
You won't find anything that you could put together to make it work like that. A Watco "green flexible" waste has the trap right below the tub drain. And there are also drains which exit out the back. They have the tee pointing backwards instead of down the normal way.
